I have a front end squeak!
Hi,
I have just started to notice a squeak coming from the front left hand side sounds like it coming from lower bushing or somthing. When I am stationary and trun the wheel to the right or pushing down on the front end it squeaks.
Is there any "safe" lub that can be put on these bushers or should they just be replaced?
thanks
Rack bushings are easy to swap and are cheap from Maximum Motorsports... Another thing you can try is raising the front and spraying every bushing down with silicone spray. You should do this 1-2 times per year.
$45 per side installed is a great deal at an actual Ford dealership :nice:
For just the parts $45 sounds like a price you can beat on teh interwebs...
Inner or outer? The inners need a special tool to DIY easily.
Because you drive it like you hate it? ;) Don't they sell a whole frent end bushing kit for not too much?
Well, Maximum Motorsports has a polyurethane and an aluminum rack bushing kit. They are both great kits I installed the poly on my GT and I am going to do the aluminum on my Cobra.
But he said his tie rod ends are the problem...
Seems to me that Ford would be the Most expensive place to buy. I'm sure there are a lot of better options. Tons of aftermarket parts companies for our mustangs. And i'd definitely install them myself to save cash. I think you may also need an alignment afterward. Check the classifieds on here for the bushings. Good luck.
