  • 1994 - 1995 Specific Tech
I have about HAD IT!!!!
  • Thread starter Thread starter 95gtdude
  • Start date Start date Apr 18, 2007
First Prev 2 of 2
officer dick
26
NC
Apr 18, 2007
#21
  • Apr 18, 2007
  • #21
I had a similar problem last July with my 94 GT. Never found out what it was, had to trade it in for an 03 Focus due to my lack of resources at the time, and I was on my way to a new duty station. I hope you can find out what it is, my problem was progressive and I couldn't find a shop that knew what to do.
WHITE94COBRA
816
HUNTINGTON BEACH
Apr 18, 2007
#22
  • Apr 18, 2007
  • #22
BlackVert said:
i'm pretty sure he's referring to the fuel pressure regulator
R
Rock777
195
Troy, IL
Apr 18, 2007
#23
  • Apr 18, 2007
  • #23
BlackVert said:
sounds like the dizzy might be 180* off to me
I was thinking the same thing......or maybe a couple plug wires crossed...
MI95Cobra
451
Oklahoma City
Apr 18, 2007
#24
  • Apr 18, 2007
  • #24
sounds like timing to me...
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 18, 2007
#25
  • Apr 18, 2007
  • #25
check all your plug wires and make sure none are mixed up
also you never said anything about how your timing was set
DDSTANG94
465
FRASER, MICHIGAN
Apr 18, 2007
#26
  • Apr 18, 2007
  • #26
m0l0 said:
That PIP is causing more and more headaches, almost every 3 days someone will post a stalling problem , we should do some sticky Stalling topic with information on the Sensor and how to change it ( cheap route ) , or just installing another dist, this reminds me that also the radiators have a lifetime of exactly 10~ years, no matter what stang ive seen but all with 10 years + oem radiator will start leaking, seems to apply to the PIP.
Ohh well i think our cars are showing the age they have
13 years old and not a problem with either.
Pokageek
2,767
MA, USA
Apr 18, 2007
#27
  • Apr 18, 2007
  • #27
o sheesh, did you figure this out? i hope so.. honestly, it can only be a few things so dont dispare. Cars are relatively simple, they are only made up of so many man made parts. Now the universe..
OrangeMustangGt
1,976
Cape Cod, MA
Apr 18, 2007
#28
  • Apr 18, 2007
  • #28
That sounds like a bad MAF......also why not replace the pip? Its only 30$ and all you need is some punches and a hammer
D
Dante30
34
San Diego
Apr 18, 2007
#29
  • Apr 18, 2007
  • #29
I noticed you have recently changed you intake manifold, or had it off the car, then put it back on. Check for vacuum leaks, especially around the lower intake manifold seal to engine block! This is often overlooked and could easily cause the symptoms that your car has right now!
JJ95GTID
1,141
Phoenix, AZ
Apr 19, 2007
#30
  • Apr 19, 2007
  • #30
X2
ON a side note: I have replaced the TPS, IAT, ECT, MAF, both HO2s, alternator, and the A/C high pressure switch so far.
I figure the TFI, PIP, IAC, EGR, CCRM will be the next victoms
gcomfx.com
3,690
Republic, MO
Apr 19, 2007
#31
  • Apr 19, 2007
  • #31
I made a similar comment a year ago. Since then, I've replaced both.
DDSTANG94
465
FRASER, MICHIGAN
Apr 21, 2007
#32
  • Apr 21, 2007
  • #32
haha..ya I probley just screwed myself over.
trav_19
810
Jackson, MI
Apr 21, 2007
#33
  • Apr 21, 2007
  • #33
hmmm you said you put in a new maf but it sounds to me like maybe its got something on the sensor i would clean your maf when mine is in need of cleaning if i start it and try to give it gas it will stumble for a second and die or stubble a second before it revs so i would focus on your maf right off hand
TrueBlue95GT
966
Connecticut
Apr 21, 2007
#34
  • Apr 21, 2007
  • #34
I'm not sure about this, but when you bought the new TPS sensor, did you bring the old one in to match the numbers? When I replaced mine, Ford said that there were 2 part numbers for our Throttle position sensors.
95gtdude
96
anywhere the military takes me
Apr 22, 2007
#35
  • Apr 22, 2007
  • #35
ok guys Trick flow is STUPID! This is what I have found out. When I replaced the intake I noticed that the valve covers had no place for the Oil fill port. So where does it go? Into the back of the lower intake manifold where the PCV valve is suppose to be. HMMMM I say, well I guess it takes out the PCV valve thinking it was built in the lower manifold or something (I know that was a dumb thing to think) and the vaccum line goes from the oil filler neck (now located at the back of the engine) to the Upper Manifold to relieve the crankcase pressure. Well turns out that that there was nothing to regulate the pressure coming from the crankcase (like a PCV valve is supposed to do) so in essence creating a massive vaccum leak with in the engine. So I disconnected the hose from the filler neck and taped it off and added a hose to the oil filler neck to relieve the pressure from the crankcase until I can figure out what the hell to do with out a PCV valve. Any body else know what to do? PICTURES will be helpful!!!!
95gtdude
96
Apr 22, 2007
#36
  • Apr 22, 2007
  • #36
Yeah I broke it and took it back got a new one and it work fine.
95gtdude
96
Apr 22, 2007
#37
  • Apr 22, 2007
  • #37
actually the New MAF was the wrong one (for a bullitt) So I sent it back and should be getting anew one on wensday.
TurboSnake95
1,402
Spanaway, Washington
Apr 22, 2007
#38
  • Apr 22, 2007
  • #38
Well I can say that awhile back, I had the exact same issues you originally described, and we thought it was all those items that you have currently fixed. But what we found out was that the Fuel Pump went bad What had happened was that my Aeromotive 1000 went bad and was barely pumping any fuel, just enough to piss you off and check everything else..... So I went and ordered a new Eliminator Aeromotive fuel pump and BAM!!!! the Cobra ran like a champ.
Just food for thought.
Will
Pokageek
2,767
MA, USA
Apr 22, 2007
#39
  • Apr 22, 2007
  • #39
Dont forget that you still may have to tune that MAF. Some people do and some dont. For me, it was all the difference etween driveable and not..
First Prev 2 of 2
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Monday at 12:38 PM
Fox 5.0 Mustang Tech Yesterday at 7:31 PM
mikeah
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
