I know, its probably simple...
88LX
327
Chicago, IL
im doing new calipers and hawk pads and i cant seem to figure out how to get the stock calipers off. its driving me crazy, and im scared ill bust a brake line. any advice would be appreciated. thanks.
Oh yeah, that if your going to disconnect it at the frame bracket. If you just going to undo it at the caliper just use a wrench on it (I forget the size ) BTW it a good time to upgrade to some braided stainless hoses (if you haven't do so already) since you doing the calipers anyway.
cool. do i use the flare wrench for the hose on the bracket or the use it for the line? i tried using a wrench for the hose at the bracket and all it did was bend the bracket. yeah ill probably get some SS hoses. i didnt even think of it till now.
88LX said:
im, still having trouble getting that hose off the frame rail. ive got a flare wrench and ive removed the c clip. it just wont budge. what am i doing wrong?
I found a 11mm flare wrench to fit very nice and snug. Hold the flex line nut with an 11/16 (?) wrench when you try to turn the fitting. Good luck - they are a b-itch to do.
