I need help finding an engine!!!
  • Thread starter Thread starter Y2K4 STANG
  • Start date Start date Jul 13, 2006
Y
Y2K4 STANG
36
NEWPORT NEWS VA
Jul 13, 2006
  • Jul 13, 2006
I have a 67 coupe and want to put at around about 400 horse motor in it. I want to keep the C4 and 8" rear (with a trac-loc 3rd from Ebay). Ive got about $5,000 to spend on a motor and I also need to get away from the old points system. Jasper has a 395cid that puts out 375hp and 425lb-ft for $3500. That just sounds like its alot of motor with no power. Its got a baby cam but it just sounds odd to me Someone help me spend my money
1320stang
4,329
23
89
Edmond, Oklahoma
Jul 13, 2006
  • Jul 13, 2006
http://www.keithcraft.com/ads/index.html#2
Scroll down towards the bottom.
67Dylan
259
Phoenix, AZ
Jul 13, 2006
  • Jul 13, 2006
Is it a stock block? RWHP? What else on the motor when they dynoed it? If it's a stock block you can imagine why they are keeping the power at a safe level.
What do you want out of the car/motor?
Y
Y2K4 STANG
36
NEWPORT NEWS VA
Jul 13, 2006
  • Jul 13, 2006
http://www.jasperengines.com/pdf/c2-ford315w-395-375hp.pdf
Heres the lit. on that engine. I want something I can cruise on Saturday night and can take to the track and run low 13s. Will the factory 8" hold up or do yall think I need to go with a 9". Im not going to the track every weekend but maybe once every two months. Thanks for the help
D
Dejavu
25
LONGISLAND
Jul 13, 2006
  • Jul 13, 2006
I know a custom builder who has done a ton of street and race engines for a very reasonable prices. He just got back from Denmark setting up small block 427 for a Vette (they loved his work so much they paid his trip over thereto set up the car) He is just over the border in southeastern PA.
Anyway if you email me I will give you his Email address and you can give him your wish list.
Good luck,
Fred
302 coupe
1,952
Macon, Ga.
Jul 13, 2006
  • Jul 13, 2006
you only need about 300hp at the fly to run low 13's. You can do that with a pretty mild 289. Most people don't because most people only focus on the engine and pay no attention to the supporting parts that put the power to the ground. A basic 351W will get you there no problem. That jasper engine would be a good street engine, probably has a nice flat torque and would get good gas mileage, as far as 351's are concerned(they all drink too much gas). Personally, if I were you, I'd go for a 331, with a mild hyd. roller cam, maybe a set of trickflow heads, RPM or stealth intake, 650 cfm carb, 1 5/8 longtubes. With a set of 3.50 or higher gears and the right torque converter, you'd be running low 13's driving like your grandma. With an auto trans, I think the 8" will last for a while.
bnickel
5,640
lubbock, texas
Jul 13, 2006
  • Jul 13, 2006
as far as the 8" holding up, 302 coupe is pretty much right, it will hold up fine with an automatic, provided you only use a mild stall convertor and don't run a trans brake or slicks. if you decide at some point you want to go with a brake and/or slicks you can say goodbye to the 8".
engine wise, a 331 is also a good way to go. even a pretty mild stock stroke 5.0 will do what you want, mild street cruiser and 13's. the key is the heads, cam and gears for the most part. of course you don't want an engine that has 8:1 compression or a 2V intake but that's pretty much common sense i think.
70MachI
25
  • Jul 13, 2006
Try getting in touch with FPS. They are based in Cali. I bought a short block from them. Great customer service.
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
I need help with an 06
  • boviske underwood
  • Oct 30, 2025
  • Services - Tuning, Welding, Mechanic, Body Work...
Services - Tuning, Welding, Mechanic, Body Work... Oct 30, 2025
boviske underwood
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
