  • SN95 4.6L Mustang Tech
I need help running some heavy weight oil please
  • Thread starter Thread starter Killa
  • Start date Start date Nov 10, 2007
Killa
1,006
56
49
Nov 10, 2007
  • Nov 10, 2007
My car is burning oils, im currently using maxlife 5w/30. The car is burning oils, my mechanic saying that I should use heavy oils 20w/50....... something like that, any recomment oils or oil addictive ( lucas ) thanks
the98stang
2,408
Clovis, CA
Nov 10, 2007
  • Nov 10, 2007
Try 10w-30 non synthetic. 20w-50 is pretty thick for 4.6 clearances.
2000fordstanggt
404
Westland, MI
Nov 10, 2007
  • Nov 10, 2007
isnt there something about a bad pcv making it burn oil? or lose it
RandyStinchcomb
1,159
Randallstown, Md
Nov 10, 2007
  • Nov 10, 2007
you need to find another mechinex........Do Not use ANYTHING heavier than 10W40 in a Modular or you will run the risk of ballooning the oil filter...how is your car "burning" oil? do you sea bluish' smoke on start-up or when you get on it?
using a qt of oil every 1k miles is considered normal asper FoMoCo.......
more info please
Killa
1,006
56
49
Nov 10, 2007
  • Nov 10, 2007
more info please
The car burn alot oil when HEAVY stop and go traffic.
If I turn off the car and turn it back on right away, I saw a cloud of smoke.
Some time it smoke if I rev high on it.
so 10w/40 is safe ? what oil should I use ?
RandyStinchcomb
1,159
Randallstown, Md
Nov 10, 2007
  • Nov 10, 2007
RandyStinchcomb
1,159
Randallstown, Md
Nov 10, 2007
  • Nov 10, 2007
10W40 is safe but thicker oil is NOT going to slow-down the oil burning process..... if it is burning oil, no sense in buying the $$ synthetic, just get some regular old "dino" oil, like Motorcraft, Quaker State, Castrol or?
how many miles on the engine?........... could be just worn-out valve seals
Killa
1,006
56
49
Nov 10, 2007
  • Nov 10, 2007
137k miles and Im trying to let it survice the winter, next summer will drop in PI engine. I think the valve seal too. Is lucas any good ?
RandyStinchcomb
1,159
Randallstown, Md
Nov 10, 2007
  • Nov 10, 2007
at this point, it can't hurt
the98stang
2,408
Clovis, CA
Nov 10, 2007
#10
  • Nov 10, 2007
  • #10
Like Randy said, the oil filter will balloon, and the motor clearances are very tight, so these engines can't handle super thick oil. I would do a compression test/leak down test to see what the rings/valves look like. If the test shows low numbers, and the numbers rise after pouring 1tsp of oil down the cylinder, then your rings are worn. If that's the case, I would run 10w30 "dyno" oil, with a oil seperator to catch the oil in the intake system of the car. Lucas is fine too, just don't keep it in the engine for more than 3,000 miles. The lucas might actually free sticky lifters or seal the valve seals a little. But I would do the compression test first, just to see what the problem is.
Killa
1,006
56
49
Nov 10, 2007
#11
  • Nov 10, 2007
  • #11
10w/40 is my choice
Havoline
Pennzoils
Quaker state
any one have exper on these 3 oils ? thanks
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
SBF rebuild with no oil pressure NEED HELP
  • Falcon67
  • May 27, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2025
horse sence
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
