  • 1994 - 1995 Specific Tech
I need longer pushrods, yeah!
  • Thread starter Thread starter red94fiveo
  • Start date Start date Mar 19, 2004
red94fiveo
1,269
Wichita, KS
Mar 19, 2004
  • Mar 19, 2004
Went over and talked to the guy at the shop thats working on my car yesterday. Unfortunately he hasn't gotten much done since the first thing he noticed when taking apart my stuff is that my valvetrain geometry was a little off, and I probably need longer pushrods. He thinks I need a 6.400" pushrod, I have 6.250" right now. Once again this is something I checked and thought was close enough that it was OK, but not the case.
He also said that having the pushrods I do now, wouldn't be the cause of my loss in power, but still needs to be corrected (I agree). He's got a bunch of different length pushrods, but he was going to fab it up with the 6.400" first, and then if thats the right size, order those, reassemble and then hopefully diagnose my problem. I am very confident this guy knows his stuff, the more people I have talked to, the more he seems to be the 'mustang guy' in town. He had a couple of engines assembled for a couple of his mustangs that he showed me some stuff on, it all looked really good.
Anyway, just thought I would give a little update, and if anyone needs a set of Engine Werks 6.250" hardened pushrods w/ less than 50 miles on them, just let me know!
zenboy99
2,212
Madison, WI
Mar 19, 2004
  • Mar 19, 2004
Thats interesting, I wonder if any of the other FTI/AFR guys had to use longer pushrods?
mto502
357
Ancaster, Ontario
Mar 19, 2004
  • Mar 19, 2004
I bought the Trick Flow package including cam, rods, heads and intake but since I landed up going with Canfield heads instead, the rods that came with my Trick Flow package were too long. I landed up retaining the stock sized pushrods but they were the Ford Motorsport hardened rods.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Mar 19, 2004
  • Mar 19, 2004
I'm just about to finish my engine with AFR/FTI custom cam and I needed longer pushrods. 6.350 is the exact lenght I chosen to have a perfect geometry. I'm receiving them and installing them on Monday so I'll confirm.
9
94DreamGT
593
Indiana
Mar 19, 2004
  • Mar 19, 2004
Hmmm...Ed sent me 6.250" length Engine Works hardened pushrods. When I checked the geometry, the sweep was pretty much near the center of the valve stem.
It is weird though that my heads are milled 0.020" and I figured that was the difference from the 6.25" to the stock 6.27", but apparantely Ed sent you the same size. I wonder why?
I also must ask why this guy thinks you need longer pushrods, what was his exact reasoning?
Unless I have a specific knowledge that mine were to be wrong, I'm not changing them. I trust Ed's following on the parts he sold me.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Mar 19, 2004
  • Mar 19, 2004
I used 6.272 for awhile, and the geometry was adequate, but when I replaced my pushrods I switched to 6.300 for optimum geometry...
Dave
Killercanary
The car that set the bar.
Altoona, PA
Mar 19, 2004
  • Mar 19, 2004
I'm running 6.300" with shims on my pedestal mount heads.
TheRedBlur
15
seattle
Mar 20, 2004
  • Mar 20, 2004
sounds like a set of Holley's or canfields. Any problem with guideplates on those heads?
mto502
357
Ancaster, Ontario
Mar 20, 2004
  • Mar 20, 2004
In what regards ? The guideplates and everything else went together just fine.
red94fiveo
1,269
Wichita, KS
Mar 20, 2004
#10
  • Mar 20, 2004
  • #10
When he showed me where the rockers are now hitting on the top of the valves, its a little back of center, so the longer ones make sense.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Mar 20, 2004
#11
  • Mar 20, 2004
  • #11
Keep in mind that being off center is not the most important measurement. Most important is that the width of the contact patch is as narrow as possible.
TheRedBlur
15
seattle
Mar 20, 2004
#12
  • Mar 20, 2004
  • #12
I had to grind mine, I checked the geometry wiht the guideplates when I got them and the plates pushed the pushrods out of the cup for my lifter. kinda hookey
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Resolved Tapping sound on passenger side of engine
  • sav22rem22
  • Jun 21, 2024
3K
Fox 5.0 Mustang Tech Sep 22, 2024
sav22rem22
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
