I need to do a full engine diagnostic! What is standard?
So I need to do a compression test, fuel pressure test, vaccume test, and timing check.
My car is having some serious motor trouble. No power, backfiring, and an "Electric-y grinding noise"
As of now i am thinking the best possibility is the timing chain has jumped a tooth.
I am going to get these tests done one way or another.
What should I be looking for with the compression test, Fuel pressure test, and vaccume test? what might be some general indications as to what might be wrong for the results I my get?
How many miles are on the car?
Is it the car in your sig?
Carbed or injected?
What's the condition of the tune up parts?
And wtf is "Electric-y grinding noise?"
Need a little more info before you just start checking **** that may not be necessary.
Did this problem just come from no where or was it an ongoing one that gradually got worse? The more detailed info you supply the better chances are of getting some help.
It is the car in my sig. Injected, 70000 + miles.
I have absolutely no power when I drive. It started out not to bad but then very quickly got to where it is now. It feels like I am taking off in fourth gear from 1000rpm when I get on the gas.
Everything is the motor is stock I need to run all of the tests to find out what the condition of the parts are.
I have gotten so many different possibilities that these checks are necessary.
The noise can best be described like a stone wheel spinning on concrete accompanied by the sound of a mig welder.
I am just curious what some possible Indications my test results while imply.
Have you ever thought about taking it to a technicain who knows what they are doing? I know everyone and thier dad thinks they are master techs but really, get real. Unless you have all this equipment, these test are going to cost you. A good tech will probally figure out your problem without them quite quickly. So, what if you get these test done or even do them yourself, are you going to know what to do with the readings, and why they are reading what they are?
Where exactly is this sound comming from, that should be your first place to look.
It is very unlikely that the engine's timing chain has "jumped a tooth".
Do the simple stuff first...
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Post the codes & we will help you fix them.
Don't put away your paper clip just yet...you'll need it to do a cylinder balance test...
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 for everything OK, or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
Use an automotive stethoscope to help isolate the noise. Don't have one and the auto parts stores don't have one for less than $8-$10 or so? Use a long screwdriver against the bottom of a empty tin can. Put the blade end where you want to check and the handle against the bottom of the tin can. Put you ear over the opening and you'll be amazed at what you can hear. Move around in the engine compartment, putting the blade anywhere there is a bearing area or a cover over a moving part. When the noise gets loud, you have found the area where the problem is.
Once the codes have been dumped and fixed, it's time to do some simple preventive maintance. Replace the fuel and air filters.
If you have a K&N, and Mass Air, clean the MAF element. The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
If the spark plug mileage is over 50 K or is unknown, replace them. I like Autolite 24's for stock heads. Look closely at the spark plug wires for damage, loose connections or burnt spots. Run the car in the dark with the hood open. Look for sparks or glow around the spark plug wires. Replace any wires that show these symptoms.
Do all this first, and then think about a compression test, vacuum test & fuel pressure test. All of these tests require some tools that you may not have or be able to rent from your favorite auto parts store.
