- May 27, 2007
- 16
- 0
- 0
I got my car dynoed today. Actually I had it first dynoed a few weeks ago only to learn that I pegged the MAF and that the stock fuel pump was loosing pressure at 5,000 rpm. Here is what I had before:
-01 GT 40k miles
-Ps1c Procharger 8lbs
-2 core intercooler
-42 lbs injectors
-Stock manifolds
-Offroad Xpipe
-80mm Mass Air ------------------Made 366 hp and 352 ft/lbs
-Accufab 75mm TB
-Accufab Plenem
-Diablo Revolution Chip
-3.73 gears
Here is what I have now:
-01 GT 40k miles
-Ps1c Procharger 8lbs---added AFM power pipe
-2 core intercooler
-42 lbs injectors
-Stock manifolds...
-Offroad Xpipe
-80mm Mass Air-----added a MAFia
-Accufab 75mm TB
-Accufab Plenem
-Diablo Revolution Chip--------changed to SCT Xcal2
-3.73 gears
ADDED: focus fuel pump
Got a dyno tune..
Now the car made 391 hp and 398 ft/lbs I spent over $1,000 to gain 23 hp..Should I be getting more hp? My goal was 420hp.
My tuner says that the car is loosing voltage at 5,000 rpm and that its only has 12.3 volts after 5k rpm.. This common? He stated that I should change the alternator...You think hes right or is it common? Thanks in advance..I have a 10 lb pulley for it but he wouldnt put it on untill I fixed the voltage problem...Any other suggestions? you think Ill get 420 hp with 10lbs?
-01 GT 40k miles
-2 core intercooler
-42 lbs injectors
-Stock manifolds
-Offroad Xpipe
-Accufab 75mm TB
-Accufab Plenem
-3.73 gears
-01 GT 40k miles
-2 core intercooler
-42 lbs injectors
-Stock manifolds...
-Offroad Xpipe
-Accufab 75mm TB
-Accufab Plenem
-3.73 gears
Got a dyno tune..
