I'm looking for some advice as to what all I need to buy to procharge my 2002 Mustang GT. First off, here's my current major mods:
- Fox Lake 2V stage 2 heads (03-04 with deeper spark plug threads)
- VT Stage 2 N/A cams
- Comp Cams high-load valve springs
- Hooker long tube headers
- Steeda underdrive pulleys
- Accufab upper intake plenum and 75mm throttle body
The MAF, fuel system, and shortblock are stock. I have a custom dyno tune.
I currently have 308 RWHP and 323 RWTQ.
Here is my long-term plan:
Supercharge the car as it is now, without building the shortblock. My target will be 450 RWHP. In about 2 years, I plan on building a new shortblock, probably a 4.6 bored and stroked to 5.0. I'll up the boost to somewhere in the 15-18 psi range on 93 octane fuel. My target then will be 600-650 RWHP.
I was thinking of getting the Stage II tuner kit with the 3-core sheetmetal intercooler. I have no idea what the ProCharger kits come with, but I'm told they come with everything I need except spark plugs. For those, I was thinking of NGK TR-6s. I installed Vacuum/Boost, Fuel Pressure, and Water Temp gauges a couple weeks ago. Is there really nothing else I will need?
1. Does the kit come with sufficient fuel system upgrades to support 450 RWHP?
2. What about the MAF?
3. Does the kit come with 6-rib or 8-rib pulleys?
4. What should I do about my 3-piece underdrive pulley set?
5. Should I do a full 8-rib conversion now, or wait until I build the shortblock and up the boost?
6. How much boost should I put into it to go from 308 to 450 RWHP?
7. How much boost should the supplied blower pulley put out at 6,000-6,500 engine RPM?
8. Does the kit include a serpentine belt? Will it be the right size for my needs?
9. Is there anything about the install that will require modifying something in/around the engine bay, such as cutting or welding, or is this just all bolt-in?
10. Does anyone have a copy of the installation instructions you could send me?
11. Am I missing anything else?
I intend to call ProCharger this week to discuss some of this with them, but any and all advice y'all can provide is welcome and appreciated.
. However for now you could put a 255lph intank pump in your car and feed it just fine, just have to modify the plastic container that houses the stock pump. The ATI instructions will talk you through it
