  • 1994 - 1995 Specific Tech
I really need help!
  • Thread starter Thread starter TheRedBlur
  • Start date Start date Apr 13, 2005
TheRedBlur
15
seattle
Apr 13, 2005
  • Apr 13, 2005
My car stalled at the light a weeka ago and now it wont start! I've replaced the ignition module, the hall effect sensor, the CCRM, and the computer, I'm still not getting any pulse to the injectors or to the coil. I don't know what to do guys, the module is getting power, and so is the computer. help me! I've been driving a fereaking malibu for a week and a half, it's disgusting.
slytherin
702
northeast ohio
Apr 14, 2005
  • Apr 14, 2005
This may sound dumb but, When you turn the key to start do you hear the fuel pump come on and pressurize? have you checked the fuel filter?
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Apr 14, 2005
  • Apr 14, 2005
i was poking around with the search button the other day, there is a good thread somewhere on here, concerning no start faults...sorry I can't link it to you, sure you could find it. BTW have you looked at all the fuses? good luck man
TheRedBlur
15
seattle
Apr 14, 2005
  • Apr 14, 2005
hmm, don't know where to start lookin for that thread. and yes I am getting fuel pressure, and my pump is priming, the issue is that the coil and injectors aren't recieving any commands. I don't understand why.
davins130
424
  • Apr 14, 2005
thats real weird that the coil AND the injectors both arent getting power... trace the circut on the injectors untill you find the spot that isnt getting voltage, thats my best suggestion and im sure youve done that already...is it throwing a code at all? too bad its not obdII or else that would be a lot easier to figure out
HISSIN50
34
129
Apr 14, 2005
  • Apr 14, 2005
on foxes (not sure about SN's since you have a little bit different stuff), the PIP is responsible for injector 'timing' signals and static spark signal. i would recheck the PIP and its wiring.
good luck.
TheRedBlur
15
seattle
Apr 15, 2005
  • Apr 15, 2005
PIP? what does that mean?
M
_MATiC
140
El Paso, TX
Apr 15, 2005
  • Apr 15, 2005
hall effects sensor as u call it..or stator..
TheRedBlur
15
seattle
Apr 15, 2005
  • Apr 15, 2005
did that
twice
HISSIN50
34
129
Apr 15, 2005
#10
  • Apr 15, 2005
  • #10
i know you did, but if you dont have spark or injector pulse, i would double check it and the wiring to it (the latter might not have been checked).
also, how do you know the injectors are not getting power? if an SN is like a fox, there is constant 12 volts to the injectors and the puter modulates ground to make them fire. a noid light is a good way to check if they are getting power and ground.
*I post generic info like that as i would be surprised if it is different for SN's vs a fox, but if it is, the SN guys can correct the info*.
good luck bud.
TheRedBlur
15
seattle
Apr 15, 2005
#11
  • Apr 15, 2005
  • #11
um I used a 921 light bulb and pulled the wires out a bit to stick them into the harnes, lights up, no pulse. my boss replaced three hall effect sensors before he got a car running once. I duno though.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 15, 2005
#12
  • Apr 15, 2005
  • #12
No spark...look at 12V at injectors (red wire), check for 12v at coil...if good and no spark..look at TFI. My TFI went out and replacing brought her back from the dead.
TheRedBlur
15
seattle
Apr 15, 2005
#13
  • Apr 15, 2005
  • #13
whats a tfi?
one of my commercial customers is gonna lend me his breakout box so I can try to get to the bottom of this.
HISSIN50
34
129
Apr 15, 2005
#14
  • Apr 15, 2005
  • #14
TheRedBlur said:
whats a tfi?
TFI = Thick Film Ignition. on an SN, it is on the pass fender - under the MAF, IIRC.
stickcar1990
#15
  • Apr 15, 2005
  • #15
does the engine crank normally? i know it sounds stupid, but is the rotor turning? u did replace the pickup in the dist? if you did all that and it still is missing the spark and injector pulse its almost gotta be the tfi module- its fairly common for those to go out, but in my experience they usually restart after they cool down.
TheRedBlur
15
seattle
Apr 15, 2005
#16
  • Apr 15, 2005
  • #16
I have fuel pressure, oil pressure, compression. the motor turns over, and the rotor turns in the ignition. actually, you have to pull the distributor shaft to replace the hall effect sensor, so if it broke, I'd know.. and yes, I have replaced the ignition module, or Thick film thingy, whatever it is called.
stickcar1990
#17
  • Apr 15, 2005
  • #17
you plugged your light bulb into both wires on the fuel injector harness and its lit constantly?
TheRedBlur
15
seattle
Apr 16, 2005
#18
  • Apr 16, 2005
  • #18
yep, lit constantly without pulse. I got a breakout box, I'm probably gonna start going on it tomorrow.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 17, 2005
#19
  • Apr 17, 2005
  • #19
i have no clue but when you figure it out let us know of course! are you comming to the meet next weekend? peace
john
TheRedBlur
15
seattle
Apr 17, 2005
#20
  • Apr 17, 2005
  • #20
**** john, I hope I can make it. I miss driving my car and leaving hte house whenever I want.
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
