  • 1994 - 1995 Specific Tech
i shorted something (flasher box?)
  • Thread starter Thread starter vladasap
  • Start date Start date Oct 24, 2008
vladasap
294
nyc, ny
Oct 24, 2008
  • Oct 24, 2008
hey guys
i was installing my steeda quadrant when i mistakenly touched two wires under the dash and shorted something. Now my brake lights dont light up and my hazards and turning signals are out. I heard of this issue before and it seems like its a "flasher box" or something like that. Can someone PLEASE tell me where its located and if someone has a pic of it THAT'D BE AMAZING !!!
Thank you everyone at :SNSign:
PS- I checked the fuses and they were ok. Out of curiosity which fuse would it even be? (i just pulled them all out not knowing which one it could be)
GTA_V6_Mustang
1,326
Miami, FL
Oct 24, 2008
  • Oct 24, 2008
You need to check the fuses with a test light. Sometimes they may look ok and but the appropriate way to check them is with a test light.
vladasap
294
nyc, ny
Oct 25, 2008
  • Oct 25, 2008
i hate to be a pain, and i do appreciate the suggestion, but can anyone point me to this flasher box thing. I wont be able to sleep until i look at it and possibly replace it.
As far as the fuses go, which one is it that would possibly be causing this issue?
HISSIN50
34
129
Oct 25, 2008
  • Oct 25, 2008
Fuse 9 is for the BOO and TS's. Fusebox diagram
I doubt you burned the flasher relay. One commonality for two brake lights and the turn signals is the multi-function switch (the turn signal switch). Check your brake lights again - if the middle brake light doesnt illuminate, the MF switch might not be your issue (because the 3rd light does NOT go through the MF switch).
Here's a lighting diagram
Good luck.
vladasap
294
nyc, ny
Oct 25, 2008
  • Oct 25, 2008
I will recheck this fuse later tonight
big thanks
I have my fingers crossed that i just didnt notice the fuse 9 being burnt !!!
vladasap
294
nyc, ny
Oct 26, 2008
  • Oct 26, 2008
PROBLEM FIXED!
it was a bad fuse #9 just as mentioned above.
Thanks Hissin5.0 & GTA_V6
vladasap
294
nyc, ny
Oct 26, 2008
  • Oct 26, 2008
ahhh!
problems back. They worked for approximately 5 min n the fuse blew AGAIN!
what do i do???????
HISSIN50
34
129
Oct 26, 2008
  • Oct 26, 2008
There's a decent chance your Brake light wiring is shorting to ground. Take a look at it (the switch is on the front of the brake pedal arm).
vladasap
294
nyc, ny
Oct 27, 2008
  • Oct 27, 2008
i had the brake light pedal on/off switch laying around & i replaced that last night ....so its deff not that
im leaning towards the flasher module mentioned above or if i shorted something what else could have popped other than just the fuse?? n why did the fuse pop again?? could a malfunctioning flasher box thing cause it to work for a few n pop again???
I HATE ELECTRICAL ISSUES
HISSIN50
34
129
Oct 27, 2008
#10
  • Oct 27, 2008
  • #10
If you are not using your turn signals and it blows, chances are that the MF switch is fine.
The issue is almost always brake switch wiring that shorted (not the switch but the wiring. If the switch shorts, it just makes your brake lights stay on). Look for chafed wires around the pedal assembly.
vladasap
294
nyc, ny
Oct 27, 2008
#11
  • Oct 27, 2008
  • #11
Ill take a look again tonight and ill report back
vladasap
294
nyc, ny
Oct 28, 2008
#12
  • Oct 28, 2008
  • #12
i looked at all the wires and none of them r in the way
i replaced the blown fuse 9 for the third time and everything worked for about 15 min and then it blew again
Im gonna end up biting all these wires!!!
F***ing electric problems!
HISSIN50
34
129
Oct 28, 2008
#13
  • Oct 28, 2008
  • #13
What are you doing to blow the fuse. I would do nothing but repeatedly hit the brakes to see if I can blow the fuse. If it won't blow, do nothing but use the turn signals. If it still wont blow, then hold the brakes and use the turn signals.
Doing differentials like that helps narrow it down.
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
