I smell gas.
dec322
401
Bham AL
I just bought the car Saturday and have filled it up twice (long trip to get it). Some gas overflowed out of the tank and I could smell gas as a result. But over the past couple of days I've noticed the smell inside my car and also under the hood. I don't think its running rich b/c I haven't seen any smoke. All the plugs, wires, and cap are new. The fuel injectors were just serviced before I bought the car. Is there a common problem on these cars?
Today after work, I'm going to buy something to pull codes. We'll see if that turns up anything (this is also the beginning of my quest to solve the surging idle:) )
A few things come to mind. Either the vapor management system isn't working correctly, or the drain tube is clogged. On top of the fuel tank is a plastic vent valve that recirculates fuel vapors. If it is broken or not functioning correctly, you'll smell fuel. If the drain tube for the filler pipe is plugged up, fuel will pool in it and could cause a fuel smell. Or you have no tailpipes on the car and the exhaust is being sucked up into the passenger compartment. Or the car is simply running extremely rich.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Since u said fill up, the rubber oring/gasket that is supposed to seal the filler tube on the side of the tank comes to mind. That might be bad. Try and see where its leaking from
exactly what i was thinking my car does the same thing...
Another vote for the EVAP system.
The Charcoal Cannister on a fox is up front to the pass side of the radiator. The hoses like to vulcanize at the CC and also the main line from the solenoid to the intake goes south where it sits under the plenum. If you need a replacement hose, note that some of them have two different I.D.'s at each end. Jrichker has posted some wise info about fire danger which should be heeded if considering splicing lines together to make your own hoses.
Good luck.
HAHAHAHAHA!!!!
I was looking through the topics real quick, like I always do, and I looked too fast. I thought the title was, "I smell a$$"...:rlaugh:
here's what I saw:
My brain kinda squished it all together into 1 funny sentance...yup...that's how I think... *sigh
Yeah, I know somethings up when I fill up. I'm not sure where it comes from but I falls to the ground. I can fix that easy enough (whenever I get time). I'll check the canister this weekend and also the o-rings. I had a bonneville that had the same smell and it was an o-ring problem. I just need some time to actually look into this stuff.
I look at the injectors yesterday and I could definitely see some dampness. I'll have to take the intake off in order to look at each one closer.
The messed up thing is that the guy I bought this car from said he just had all the injectors serviced (new orings and such).
You are one of the many 87-89 Mustang owners that has leaky injectors. The 87-89 cars had injectors that developed leaks around the top of th injector at the joint between the plastic and the metal. There is nothing you can do to repair the leak at this joint. You get to replace the injectors. I replaced all 8 of mine over time, and did the injector seals along with them.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit.. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end
Thanks. That borg-warner site didn't work? Maybe its just my computer acting up.
So I need to replace the injectors and buy a seal kit for each injector? Common sense would put them together but I guess "the man" will get more money if the injectors and seal kit are sold seperately. :)
Does anyone support a specific brand of injector? All I need is the stock 19# injectors.
