several of you guys helped me out during all this. for the guys that are new to the problem, heres the condensed version:
swapped out my T5 in my 95 for a 32k Cobra T5 from a 95. also swapped the flywheel and bellhousing. had the cobra flywheel resurfaced b4 the install. after the swap i had vibration. the vibration happens while sitting still with the clutch in or out, with the car in or out of gear. it worsens with rpm speed, or at least changes. also does it while driving.
since the vibration occurs sitting still ( driving also ), i should be able to eliminate the trans itself along with the driveshaft, universals, etc. the cluch is a centerforce and has less than 12k on it.
UPDATED PROGESS:
i ordered a NEW FRPP 50oz replacement flywheel and dowel/bolt kit and had a mechanic take out my resurfaced cobra flywheel and put in the new one. he said everything b4 hand was installed correctly. the new flywheel DID help but i still have some vibration. still happens while sitting still but worsens while driving up in the rpm's.
i have a new in the box FRPP 50oz balancer ( not the SFI one ). should i try replacing the stock one with this one? could this fix my problem?
thanks guys
UPDATED PROGESS:
thanks guys
