I think I ruined my motor!
phalcrow
24
Ventura, CA
Newbie
Status: online I have a 1996 GT with a 1997 block and PI heads. I have been running the Comp Xtreme energy cams XE-262AH (comp part #102500) for quite some time with no problems. I just swapped them for the XE-270AH (comp part #102600) cams and as soon as I started it up, my motor sounded like a diesel. I couldn't pinpoint it the noise, it wass all over the engine. After driving a few blocks, I decided to put the old cams back in (8 hours later) and had a new noise, sort of like an exhaust leak. I reved the engine to 3-4 grand and POP! TACK, TACK, TACK, TACK every revolution. Sounded like a midget with a sledge hammer in my block. I think I have a piston to valve clearance problem. I'm more worried about that last part. Any suggestions?
Sounds like the new cams weren't quite timed right and jacked the valve(s) up causing the problem since it didn't go away when the old cams were put back. Or a broken spring. Use a stethoscope to pinpoint the exact location. On another note, an inlaw of mine had a same year, same motor thunderbird that blew a sparkplug out of the head that made the same noise as you describe.
It sounds to me like those Comp cams definitely weren't timed right! This is why you NEED TO DEGREE THEM, especially Comp cams! This is NOT new news, and there are plenty of posts on all of the boards on this topic.
I feel bad for you. You're probably going to need a couple pistons and a new set of heads. :( Then again, you may get lucky, and it could be something else but I have a bad feeling it isn't.
BTW, when you heard the noise on start-up, why did you take it for a drive? ?????
either way he is screwed.. if it's PTV then he probally damaged some pistons and the heads.. if it's a bolt down the intake then he will have piston and head damage...
most of the time a car will not run after PTV thats why I think it's a bolt or other metal object down the intake. but it could be either one of them,.
Wish I knew that before hand. Oh well, I guess I learned the hard way. I'll give an update sometime this weekend when I pull the heads. This might be a good excuse to go to ported heads and forged parts. Maybe I'll invest in dished pistons too.
trinity_gt said:
A 1997 shortblock has a smaller piston dish than the later 99+ engines do. You've therefore got less margin for timing error when using a bigger cam with PTV being the likely result.
not true...when ptv occurs on a 2V it makes contact on the perimeter not in the dish area so you could have a 30cc dished piston and still have ptv.
look at this pic of a notched 2V piston and see where the notches are located....on the outside not in the dish cause thats where it touches.
phalcrow said:
Is there any chance I ruined any rods as well? What's the best way to check if so?
it's not the rods that would suffer from PTV it's the rod bearings
Assuming this is PTV, since it stayed running there was only light contact so your rods and rod bearings should be ok. There is no way to check this without disassembling the engine.
