You spelt powder coat wrongSo, I got my pulley. The outside diameter is def larger. I cannot do a side-by-side eyeball or comparison with my shroud and all the accoutrements in the way. So, no pics yet.
I can't verify the belt lineup either.
I can say that it [looks] like should work.
and look!
Ford - Auto Specialties Performance - Quality Performance Products
What do Underdrive Pulleys do? Underdrive pulley systems increase engine horsepower by reducing the amount of power required to drive external engine accessories. For example, the alternator, power steering, water pump and air compressor rob horsepower from the engine. By replacing factory-sized...www.autospecialties.com
Their site is back up.
I'm going to do that math and get as close as I can at turning the alt and WP at OEM speeds. I guess the power steering and A/C are just going to have to hold TFon unless...
I'll have to check on those pulleys from an 87-96 Ford F-150.Might just be another bolt-on affair.
The important question is (after get this all mocked up and see if it even works etc...): I wonder what color I'll paint them.![]()
I had ASP make a 9.5" crank pulley for my race car.
I had a 2.87" blower pulley on at one time.
If you do the math, the 2.8L Kenne Bell was spinning 26,480 rpm at 8K engine rpm.
It did not make more boost. It just added heat to the air it compressed.
I was stuck at 20 psi regardless of how fast I spun the S/C.
I slowed it back down to 21K rpm and made the same 20 psi.
You could also change everything over to 8 rib.
Pretty straight forward.
What is your current Blower Pulley size?
How large of a S/C pulley do you want to go?Aw Geeze.... Uh... small... 2-5/8 (I had to go measure).
I have a pretty good assortment, although they are all 8 rib, but it would still work.
The smallest I got is 2.87" I think. A bit more than the 10% you want.BIG mistake up there... round it off to 10% !! Not 20.
Rule of thumb with KB's is that with every 1/8" of S/C pulley change you get a 1 psi boost change.
I just went out and checked
I have 4 crank pulley's
Currently on the car is a 7.8"
I also have a 8.5", 8.75" and a 9.5"
The largest S/C pulley I have is a 3.75" with 8 other pulley's going down to the 2.67"
You would need all the pulley's and I imagine the A/C one would be a bugger to get., although, with the correct dimensions sent ASP should be able to make that one as well.Just our of curiosity, what does a complete 8-rib setup go for? Does it apply to the PS pump, and A/C too?
