I still cant get my mustang to idle, i waited till i got another IAC slapped it on set the idle with the iac d/c and the spout set it at 900 rpm perfect no bobbing nothing. turn off engine pluged the iac and the spout back in. turned the car on, idles like crap around 500 to 300 jumping up and down and then engine dies after about 2 mins.
What the hell right? reset computer remove iac and spout, turn car on set this time the idle to the highest it will let me go which is about 1500 turn off car and plug in iac and spout. Same exact result 500-300 jumping and then dying engine
Now everytime i reset the computer,d/c iac and spout and try to start it up with the last settings on the throttle body screw i have to make sure that the throttle screw is turned to the max open because if I do not it will just crank over till i give it gas to start.
Even when I set the screw to any idle i want whter it be 900 or 1300 without even putting in the iac or spout as soon as the car gets turned off and i try and crank it immediately back over it will sputter till i give it gas or until the throttle screw is opened to the max
Im not sure if im even susposed to do that crapola but that was me testing it even if the computer isnt reset shouldnt it remember that idle that was set on the throttle screw? right after it was turned off and turned back on.
I have a thoguht since this is the replacment engine i got from the old one getting hydro locked this might be the wrong computer for it since we just dropped in the engine. But would that even cause any of the problems im talking about here?
