I recently replaced the IAC valve in my 97 GT with a new valve. The old one would stick closed on cold starts in the winter, but would work properly if cleaned.
Anyway, the new IAC valve seems extremely overactive. The idle will occasionally hang around 2500rpm for 5-10 seconds before settling. I also notice the engine pulls me along for a few seconds after letting off the gas, clearly because it is trying to idle faster than the current speed. This one annoys me the most. If I push the clutch in at that time, the engine speed will climb to 2000rpm and settle quickly to a normal idle.
I thought the computer just needed to learn the new valve, but I have driven it about 1,000 miles so far. So what do you guys recommend?
Try a different valve?
Disconnect the battery and force the computer to re-learn? (or does the computer not learn these functions?)
I have seen an IAC mod here before where someone recommended putting a restrictor in the IAC path to reduce idle airflow available to the valve, but that seems like such a band-aid fix. Any comments or experience with this mod?
I have a twEECer which I could re-tune the computer with. I have played with the idle settings before, but never found the right variable to reduce this surge. I have only found the dashpot to force the idle to come down faster. Can anyone point me to variable or table names to look at to reduce the peak surge when you let off the gas?
