  • SN95 4.6L Mustang Tech
IAT and supercharging
  • Thread starter Thread starter 96SCstang
  • Start date Start date Nov 29, 2008
96SCstang
228
novi, MI
Nov 29, 2008
  • Nov 29, 2008
ok, i am in the process of putting on a FMIC this winter and i am thinking that i should put my IAT sensor after the intercooler. Am I correct in this thinking or not? that would give me the most accurate air charge reading going into the engine i believe. Where are you guys putting them? :SNSign:
hotcobra03
poteet,tx
Nov 29, 2008
  • Nov 29, 2008
On my 03 iat1 and iat2 before and after
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 29, 2008
  • Nov 29, 2008
after the IC. mine is about 8" from the TB
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Nov 29, 2008
  • Nov 29, 2008
You want the IAT reading the air that's going to enter the throttle body, so yes... after blower after inter/after coolers.
Mines installed into the connector tubing between my outlet on my S/C and the inlet pipe.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Nov 29, 2008
  • Nov 29, 2008
as close to the throttle body as possible.
trinity_gt
3,125
81
99
Canada
Nov 29, 2008
  • Nov 29, 2008
Kenne Bell puts the IAT into a manifold runner so they too want to see post-compressor, post-intercooler air temperature.
blubullett
535
Modesto, CA
Nov 29, 2008
  • Nov 29, 2008
about 12" in front of my throttle body.
J
jprovence
195
Albany, OR
Nov 30, 2008
  • Nov 30, 2008
Mine is installed where the EGR used to be. Its actually a 9/16" hole. Perfect for threading a 3/8 NPT hole for the threaded IAT. Its screwed right into the plenum. It reads ecactly what is going into the motor. I had to maching about 3/8" off the plenum to get the sensor deep enough. Its perfect now.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 30, 2008
  • Nov 30, 2008
thats a great idea!!!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 30, 2008
#10
  • Nov 30, 2008
  • #10
post a pic up of that , that is a good idea
J
jprovence
195
Albany, OR
Nov 30, 2008
#11
  • Nov 30, 2008
  • #11
You can see where I had to cut down on the plenum. Some work with a cutoff wheel and a file made quick work. This enables the sensor to reach the air stream. I left about 3/4" of material for the threads. Maybe a little bit more. Nothing exact. I bought the tap for about $8 from a local builder supply store. This is on a C&L plenum, others, I don't know, but shouldn't be too much different. I did have to open up the casting just a hair on the inside so the tap would go all the way though. After that, it went right though. Not a lot of work, I didn't want to have a bung welded to the pipes, people want too much money for the welding and the bung it self. Especially aluminum. Sticking it in the coupler seems to cheezy for me.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
