  • 2.3L (N/A & Turbo) Tech
Ideas please!!!!
  • Thread starter Thread starter latroca1
  • Start date Start date Aug 31, 2004
L
latroca1
234
martinsburg,West Virginia
Aug 31, 2004
  • Aug 31, 2004
Alright here is the deal. I installed the vam on my car yesterday and had no luck. All sorts of pinging no matter what i did.
Had to go to my second interview and put everything back the way it was.
My friend and i messed with it today because i was having problems with the stock setup. I have been running it with 13 advance and 4 retard on my roller before i did the la3 swap with no problems besides the other night i thought i heard a knock in 3rd at about 45mph.
Now even back to stock settings i cannnot get it to stop knocking with the spout in.
This is cam at 0 and 10tdc. I have tried anywhere from -7 to +7 on the cam and anywhere from 4 retard to 22 advance on the dizzy. Stiil the same besides eliminating knocking sitting or going on a pull.
With the spout out at 14.5 advance dizzy and 4 advance on the cam. She runs awesome I actually was able to dump the clutch and burn the tire with 16's and possi. I could not do this before at all period!!!
So with the spout in it knocks when you start it then goes away but on a pull around 2200 she knocks this is with different cam settings and advancemts of the dizzy.
I have ran codes and nothing.
Fuel pressure good
Swapped knock sensors
Plugs and wires good
It seems like shes advancing way too much on her own. Could this be a bad tfi or pip?
Like i said i havent changed a thing besides putting a gutted upper and ported lower but i don't think it would cause a spark knock.
With spout out is good but really would like to have my control of advancement.
So any ideas would be great i would like to try the vam again. I think if i can solve this issue then all will be good.
Thanks!!!
89' n/a Hdr,RCrtrd4,ADJCMGR,2.25Exh,HFCat,HFMuff,8.83.73Grs,AWD,Lwrd,95GTTB,3"Cai,Koniadj84' SVO Being fully restored
Stinger
7,754
24
118
Basehor (Kansas City), KS
Aug 31, 2004
  • Aug 31, 2004
Check what your timing is at idle with the spout out and spout in...in should be about 28 degrees.
L
latroca1
234
Sep 1, 2004
  • Sep 1, 2004
I'm running with the spout out now!
Base timing is at 13 degrees. it's the only way i can run with out the knocking with the spout in.
Cam is set to 4.5 degrees advance.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Timing not advancing/retarding
  • PonyGTrider
  • Aug 16, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2024
