Idle Comes Down Slow After Heads & Cam Swap
Timm10221
25
Here is a list of my mods for reference:
Smog Delete
Ac Delete
PS Delete with FlammingRiver Manual Rack and Pinion
Spare, stereo, rear seat, jack gone
Engine:
Running only Alt, water pump, and crank pullies u/d Pullies
MSD coil, Summit Billet Dizzy w/ MSD cap and rotor, FRPP wires. MSD Blaster Coil
75mm Mass Air Meter cal. for 30# inj
FRPP 30# injectors
CAI
70mm TB
Edelbrock intake Elbow (70mm)
Cobra Intake Manifold
Pypes Shorty Headers
Pypes o/r X-Pipe
Mac Produmps 3 inch
Timing at 14*
TFS roller Rockers 1.6
255 Walbro fuel pump
TFS-51400004 Heads 170's
TFS Stage 2 cam
All I swapped was my heads and cam, since the swap my RPM's take forever to come down after a rev. So I started to do the usual things ie: tps voltage, and iac restrictor plate. I set the tps voltage to .99v in several spots and made the restrictor plate and with one of the holes just big enough hfor the car not to die, I rev it and still has the slow rpm return. Before the heads and cam swap the car was very reponsive and rpms came down quick. How can I check to see if my IAC is bad? and anymore sugestions on how you might have fixed yours would help... I am kinda at a stand still on fixing this.
Tim
