Idle issue when hot
  • Thread starter Thread starter Csheets88
  • Start date Start date Apr 22, 2024
C
Csheets88
Apr 22, 2024
  • Apr 22, 2024
Hello everybody. I have an issue I can't figure out. I have an 89 foxbody with edelbrock heads. F303 cam. Cobra intake. Shorty headers. It'll crank and drive fine. After about 20 minutes of driving and sitting at red-light it will seem like something kicks on and the idle gets super rough. Doesn't seem to affect during driving though, but it will idle bad enough to where it will sometimes die.
nickyb
I gotta say i never painted my nuts, Never Ever
2,983
1,632
153
nevada
Apr 22, 2024
  • Apr 22, 2024
Could that something that kicks on be an electric fan or is it still stock fan?
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,945
5,816
213
Apr 23, 2024
  • Apr 23, 2024
Intake air temperature sensor. Seems like it may be your issue....or the coolant temperature sensor. Not the one that looks like a little stud but either the one in the coolant bypass pipe or the one that screws in the intake under the upper intake on drivers side. If the sensors are disconnected or not working it will make the computer think the car is still cold.
AeroCoupe
6,026
4,142
183
Claremore, OK
Apr 23, 2024
  • Apr 23, 2024
Even if the CEL (check engine light) is not on there can be codes. This is due to only emissions related codes setting the CEL. I would pull codes first then go from there.
C
Csheets88
Apr 24, 2024
  • Apr 24, 2024
Stock fan. I've pulled codes. Nothing outta the ordinary. Smog stuff, it's been deleted. It has new coolant temp sensor, tps, and aic. I've replaced the thing on the side of the dizzy. (Can't think of the name) And a new msd coil. Cap and rotor are msd as well.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 24, 2024
  • Apr 24, 2024
The EEC changes logic at around 170 degrees so I would check the IAT
C
Csheets88
Apr 24, 2024
  • Apr 24, 2024
Could this cause an issue with the rpm guage? I have the stock and an auto gage. The stock will bounce around with a blinker on or heat on. But it's not consistent
General karthief
Mod Dude
Aug 25, 2016
27,983
10,611
213
polk county florida
Apr 24, 2024
  • Apr 24, 2024
Check the ground wire that's bolted to the back of the left (drivers side) head and goes to the fire wall.
Does the alternator charge sufficiently at idle? Needs 13.5 volts or close to at idle.
C
Csheets88
Apr 24, 2024
  • Apr 24, 2024
Not completely. It has a newer Motorcraft alternator. Oem
C
Csheets88
Apr 24, 2024
#10
  • Apr 24, 2024
  • #10
With heat and head lights on it will drop it
nickyb
2,983
1,632
153
nevada
Apr 24, 2024
#11
  • Apr 24, 2024
  • #11
Time to upgrade to a 3 G alt.
General karthief
Mod Dude
Aug 25, 2016
27,983
10,611
213
polk county florida
Apr 25, 2024
#12
  • Apr 25, 2024
  • #12
These are not answers that help, the volts will very according to RPMs normally, need to get familiar with diagnostic tools and terms, beg or borrow a volt/olm meter, read voltage at idle, nothing on, and then with blower, lights and wipers on, then say 1800 RPMs, and battery voltage with engine/key off. I have to write things down cause my memory bank is mostly full of useless crap that takes up too much space.
Also need to monitor fuel pressure to see if/what changes when it starts to act up.
We can point you in the right direction, a good start would be a repair manual or better yet an assembly/repair manual by Ford, ebay has some.
Some helpful info can be found in on the tech main page:
Technical Thread/how-to Index
Guys, if "that should be a sticky," then please reply to this thread with the link to your suggestion and why you think it should be added. How to determine if a thread should be included: - Does the topic address a common fox 5.0 owner's needs? / Is it a frequently asked question? / Is it...
stangnet.com
There is some info on the 3g alternator upgrade in there too.
J
Jarhead67
5 Year Member
Nov 24, 2018
172
64
38
Windsor Locks, Connecticut
Apr 27, 2024
#13
  • Apr 27, 2024
  • #13
The thingy on the distributor is the TFI. Did you get the proper one for your car/transmission? Auto car takes a different one than standard.
J
Jarhead67
5 Year Member
Nov 24, 2018
172
64
38
Apr 27, 2024
#14
  • Apr 27, 2024
  • #14
To stop the idle drop when there’s a load (lights or heater blower) get a 130 amp alternator kit.
C
Csheets88
May 1, 2024
#15
  • May 1, 2024
  • #15
AIT didn't correct it.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 19, 2026
CAMTWO1070
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
P
High idle issue and leaking after running.
  • PHoffman
  • Dec 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
General karthief
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
