Idle Only With Full Choke?
Jared Zecchel
Hey everyone, in need of a little advice.
My engine was running fine (maybe a little too rich) until I swapped the spark plugs. All of a sudden the engine starts misfiring and running terribly even after i checked the gaps.
I watched the mechanic down the street tweak the carb a little and he seemed to set everything strait.
Maybe a week later it starts running crappy again. I took it back and he said that the engine was flooding and to rebuild/buy a new carb.
Now it wont idle unless the choke is fully on which makes me think that the engine isn't flooding but rather it has a vacuum leak.
I rebuilt the carb to be on the safe side but still nothing.
I tried the WD40/Carb cleaner spray trick but still nada.
I pumped a bit of smoke in there and there seemed to be a pinhole leak by the opening for the throttle rod but not enough that i would suspect it to make such a drastic difference in the car's performance.
Any idea's?
Vacuum lines are fine. Just replaced them.
All signs point to a fuel delivery problem.
Apparently I didn't clean the jets as well as I thought.
Took it out and did a whole new number on them and now she idles nicely.
Vacuum is 20Hg's idling but 15 when I slip it in gear.
Is it normal to drop so significantly?
