Since the Kitty was professionally done.......I have questions on one I am doing myself.
1965 Pony Coupe
289 A block - stock except for the Edlebrock 600
T-10
Was missing very badly but no smoke. Found out the coil was leaking so replaced it. Then discovered intermitent fire on No. 2. I guess the coil messed up the distributor since everything was burnt. Replaced the distributor. Fires on all 8 now but seems to be constipated. Vacuum shows 10-12 with rapid movement at idle. Book does not explain this one to me.
Blocked exhaust??? - sounds like it is muffled?? Dual exhaust, turbo mufflers.
Intake manifold leak??
What is my next step??
Thanks
1965 Pony Coupe
T-10
Thanks
Good Luck
