If you take the Ac out how much HP
He's most definitely kidding, if you really want to know what it will feel like... launch from a red light with it turned on, then launch with it turned off. That's exactly what you will gain.
schwbs5.0 said:
are you serioud 40hp and 65ftlb or are you just messing around?
Sarcasm
Pronunciation Key (särkzm)
n.
1. A cutting, often ironic remark intended to wound.
2. A form of wit that is marked by the use of sarcastic language and is intended to make its victim the butt of contempt or ridicule.
3.The use of sarcasm. See Synonyms at wit..
All that A/C stuff weighs a good bit, and it sits in about the worse spot. Also, removing the condencer from in front of the radiator will make a difference in cooling, the air is going to hit the radiator first and flow better.
A while ago when I had A/C I ran a shortbelt bypassing the smog and P/S which dropped my 1/8th mile time .2. When the compressor started leaking I deleted A/C and could no longer that shortbelt, I had to run P/S and dropped my times down another .1. :)
Cons: Hot as hell in the hot months, both windows definitely down.
Pros: Drops 50-60lbs off the nose and relieves up to 5 hp.
True performance enthusiasts remove it :D Or maybe I'm just an idiot :(
I noticed a lil' difference in sotp feel and weight transfer. :nice:
