I built my trailer with it thread and iv done a bit of light gauge steel body work with it aswell.... I would say this is a light to mid range welder.... very suitable for anything automotive related.....
It is a lincoln MIG PAK 15, it is a wire feed welder.....
wire feed welding is the easiest type to learn by far and id say the most forgiving.....
This welder has a heat range of 30 to 175amps and wire capacity up to .045
It also has the option of using shielding gas (which in my oppinion is the only way to go)
It comes as a kit with a short video, a cheap face shield, a spool of shieldless wire (flux core wire) and a few extra gun tips... your ready to weld just as is if you wish...
I opted to get the shielding gas setup consisting of a set of gauges and a tank... unfortunatly local laws prohibit the possesion of large gas tanks unless there rented so I had to buy the small 40 cubic foot bottle
:canflag: the shileding gas allows you to use solid copper wire instead of the flux core wire and gives you a wider range of wire sizes which means a broader range of heat settings and usages and it turns this unit into a true MIG setup (I hope im getting my terminolgy correct here maybe a welder or 2 could step in here) not to mention you get a much much cleaner weld (with no slag) using the shielding gas.......
the cost....
welder kit $599
gauges and hose $129
tank (with fill) $169
stand (or build one) $50
helmet,gloves,
extra tips, wire etc.$100
the disadvantages to this welder would be its a little light for heavy duty welding, im talking like 3/4-1 inch plate..... It will penatrate 1/4 to 3/8 very good and with multi pass id feel comfortable welding 1/2 inch..... for the adverage guy this welder would suit them well.... the other disadvantage is welding outside, if there is a wind it will blow the shielding gas away causing distortion in the weld a solution for this is to crank up the gas flow but then your using more gas so.............
im happy with it.....
-gbm-
:canflag: the shileding gas allows you to use solid copper wire instead of the flux core wire and gives you a wider range of wire sizes which means a broader range of heat settings and usages and it turns this unit into a true MIG setup (I hope im getting my terminolgy correct here maybe a welder or 2 could step in here) not to mention you get a much much cleaner weld (with no slag) using the shielding gas.......the cost....
welder kit $599
helmet,gloves,
-gbm-
, Ya I know it's 220, I'll rewire the shop after i get it and decide where the best place is for an outlet.
