I notice that when I lay into the throttle, it just doesn't feel right. She'll pick up, but I would expect more with a T-5 and 4.11's. It feels like there is a delay and that she's not pulling that hard. When I hit the next gear and lay into the throttle she will kinda bog down and then studder a little while the rpm's pick up. When I pull a plug wire off while she is idleing, the idle doesn't seem to change at all, and I can here a spark jumping somewhere. When I hook a new plug up to the wire I pulled off and grounded it, I will get a nice blue spark, it's just it will not fire every now and then. What really bothers me though is the idle not changing when I pull a plug off. What gives here? Carb problems? Ignition problems? Both?
Also, about 3 days ago at work I did a little tire roasting, and after I let off the car was idling at 1200-1500 rpm's. I was able to back the idle screw out all the way, and pull back as hard as I could on the throttle linkage and the idle still didn't drop down. I shut her off, put the idle screw back in, and started her up and the idle dropped back down. What gives with this?
