ignition module
  • Thread starter Thread starter 302fordracer
  • Start date Start date Dec 31, 2005
302fordracer
738
Vancouver, WA
Dec 31, 2005
  • Dec 31, 2005
what would cause the ignition module to keep failing? my 1993 notchback started displaying the characteristic signs of a faulty ignition module (bogged hard and sputtered at 3500 rpms and the tachometer would fly all across the board, and it started only doing it when engine was hot progressively got worse and started acting this way all the time) so I replaced the distributor and bam problem solved...well now a couple months later the problem is coming back but so far it still only acts up when hot...Any ideas why this is happening?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 31, 2005
  • Dec 31, 2005
Did you pull the codes out of the motor to see what is going on?
P
PRO50SC
1,012
Olney, Maryland
Dec 31, 2005
  • Dec 31, 2005
What kinda' distributor?
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 31, 2005
  • Dec 31, 2005
Do you have a MSD or any other type ignition box? That'll cause them to go quicker...just a suggestion. Especially if its a stock dis.
302fordracer
738
Vancouver, WA
Dec 31, 2005
  • Dec 31, 2005
there is not an msd spark box however the coil is msd and no I haven't pulled the codes I don't have a code reader and I am not really familiar with how to do the koeo and koer tests anyhow. There is no CE light tho in case that helps..and the engine runs great otherwise...
302fordracer
738
Vancouver, WA
Dec 31, 2005
  • Dec 31, 2005
0h and it is an accel distributor
bill302
2,131
alabama,gadsden
Dec 31, 2005
  • Dec 31, 2005
you can purchase, or go to a library and check out a chilton mustang manual it will help show you how to retrieving codes and how to do it with a scan tool or an analog voltmeter method and it has various troubleshooting methods for diagnosing problems. check out various manuals and buy your choice repair manuals have been one of the better tools i own.
HISSIN50
34
129
Dec 31, 2005
  • Dec 31, 2005
Even easier is to follow Jrichker's post here.
Good luck.
joel5.0
429
Puerto Rico
Dec 31, 2005
  • Dec 31, 2005
If you want to run a self-test and verify the system for codes, you don't need a scanner, check
- How to run a self-test and codes scan
In your case the distributor should be under its warranty period. I would check that MSD coil, though. My 2¢.
PS: And agree with Hissin50 on Jrichker's post (saw it after posting, Great!)
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Dec 31, 2005
#10
  • Dec 31, 2005
  • #10
Don't be afraid to dump the codes... It will only take about 5 minutes and you only need a 2" piece of wire. The Check engine light will spit out the codes. No scanners needed!
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
T
  • Locked
1990 2.3L automatic - real bad engine sputtering
  • the_steve_randolph
  • Jun 13, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2024
the_steve_randolph
T
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Throttle cut out at 3500 rpm
  • Piranahbite
  • Jul 8, 2023
  • 2.3L (N/A & Turbo) Tech
4K
2.3L (N/A & Turbo) Tech Nov 9, 2023
AeroCoupe
