  • SN95 4.6L Mustang Tech
Ignition Problems
  • Thread starter Thread starter Flghtmstr1
  • Start date Start date Oct 24, 2012
Flghtmstr1
572
Springfield, PA
Oct 24, 2012
  • Oct 24, 2012
As my sig indicates, I have a heavily modified 2001 Mustang GT. After over 2 years of work on the build, I finally got the car running. Unfortunately, I am getting a ton of coil malfunction codes: p0354, p0355, p0356, p0357, and p0358. Needless to say, the car runs like crap, but I thought at first it was just the big cams, since it took a while for the codes to appear. I've ruled out bad coils as the culprit, so I'm thinking there's a wiring problem somewhere. Any ideas?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 25, 2012
  • Oct 25, 2012
If this were my car the 1st test I would do is to confirm a solid +12 volts on every COP and fuel injector with the key on.
Next I would confirm a firing pulse on the COP and Fuel injectors. A "noid" style test light is the best thing to use.
It wouldn't hurt to have the alternator tested for excessive AC ripple.
>>possible causes for P035x DTC's
Open or short in Ignition START/RUN circuit
Open coil driver circuit in harness
Coil driver circuit shorted to ground
Damaged coil
Damaged PCM
Coil driver circuit shorted to PWR
Clayton302
79
Hurricane Utah
Oct 26, 2012
  • Oct 26, 2012
how did you rule out bad coils? have you washed the motor lately, got it wet?
Flghtmstr1
572
Springfield, PA
Nov 7, 2012
  • Nov 7, 2012
I finally got a chance to work on the Mustang tonight. I verified that each coil and injector is receiving +12v. I then put a noid light on the #5 coil, and got nothing when cranking. I'll test the other cylinders tomorrow when I can get a helper to turn the key while I watch the noid light. Given that I'm getting 12v at each coil but I'm having problems with an entire bank of cylinders, should I be looking for a new PCM?
Clayton302
79
Hurricane Utah
Nov 8, 2012
  • Nov 8, 2012
No, chances of it being PCM related are slim, possible but slim. I have noticed when one coil goes bad other follow soon after. I had similar codes one time on F-150 and was reluctant to just start changes coils (COPs) but finally did and solved the problem, it has been working for over a year. Try buying a whole new set from say MSD or Accel. The OEMs are pricy and the part stores brands in general suck. I found MSDs to be the ticket. That is what I have on my KB GT and they even helped with spark blow out. A simple way to test your coils is to put a volt meter on it and check resistance, ohms. Not full proof but will give you an idea. I believe it to be 15 ohms but check a couple know working COPs and get a value, then check the suspects against it.
joshjwc9
1,095
17
39
Palm Harbor, FL
Nov 8, 2012
  • Nov 8, 2012
Is the whole driver side bank not lighting up to the noid test? It sounds like there could be a wiring issue if the whole bank is not firing, or the PCM is bad. Follow wmburns' walkthrough or PM him for more ideas..even if you clear the codes and reset the battery it still runs like crap?
Flghtmstr1
572
Springfield, PA
Nov 8, 2012
  • Nov 8, 2012
I guess I should have mentioned that before I pulled out my multimeter and borrowed a noid light, I did the resistance test on all 8 coils, and they measured within spec. I then bought and installed 4 new Pep Boys coils, but nothing changed (I returned them after the test). At this point, I think I can safely rule out coil problems, so I'm looking at either an electrical fault or a bad PCM. Given that I'm missing the entire driver's side bank but they're getting +12v to the plug, I'm leaning towards a bad PCM.
Flghtmstr1
572
Springfield, PA
Nov 8, 2012
  • Nov 8, 2012
The car still runs like crap after clearing the codes and pulling the battery. I could only see the noid light from the driver's seat when it was connected to the #5 cylinder, so I'm going to have my fiancee help me out tonight with the rest of them. I'll also test the noid light on a working coil to make sure it works lol.
trinity_gt
3,125
81
99
Canada
Nov 8, 2012
  • Nov 8, 2012
If it were mine a continuity test between the coil connectors and the connector at the PCM would next.
Check the wiring harness in behind the engine for damage. Maybe it was pinched or stressed when the engine was removed/installed.
Flghtmstr1
572
Springfield, PA
Nov 8, 2012
#10
  • Nov 8, 2012
  • #10
I tested the injectors with a noid light and they all passed. I checked the coils, and cylinders 1,2,3, and 7 checked out, but I got nothing at 4, 5, 6, and 8. I would agree that a continuity test between the PCM and coils is the next logical step. Does anyone have a diagram of the PCM connectors so I know which pins to probe?
N
n0v8or
604
Rhode Island
Nov 9, 2012
#11
  • Nov 9, 2012
  • #11
I have the 2001 factory service CD. The wiring diagram shows an inline connector between the PCM and spark coils 4,5,6, & 8 (there is a separate connector near the firewall for the other 4 coils). I am making a leap of faith that coil numbers and cylinder numbers match, but with Ford, who knows? It is a 16-pin connector and clipped to the body just below the mass airflow meter.
On my '03, I can see it if I look straight down between the passenger-side valve cover and airflow meter connector. There is a fat A/C hose running in that gap, and the connector is below it. Just follow the harness down from the front-most passenger-side coil and you will eventually come to the connector.
I would try to move that connector and harness with a stick to see if anything changes.
Reactions: joshjwc9
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 9, 2012
#12
  • Nov 9, 2012
  • #12
For the 2001 Model year, connector C104 carries COP 1, 2, 3, and 7. Connector C1007 carries COP 4, 5, 6, and 8. So n0v8or is onto something. Great call!!
I may be able to help you get a full Ford service manual with wiring diagrams for your car. PM if interested. These would be a HUGE help tracing down a possible wiring problem. Having accurate wire colors, connector pins out with face diagrams will save you a ton of time.
Reactions: joshjwc9
Modular2v
3,222
23
99
oklahoma
Nov 9, 2012
#13
  • Nov 9, 2012
  • #13
Check the fuses!
Flghtmstr1
572
Springfield, PA
Nov 9, 2012
#14
  • Nov 9, 2012
  • #14
n0v8or, you were right. I looked for that connector near the MAF, and it wasn't connected to anything! I found the other half stuffed behind the engine. I can't believe I missed that when doing the engine swap. I feel like an idiot. Thanks guys for all your help. I just hope I didn't screw up the engine's break-in period by running it on half its cylinders for 30 miles.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
