  • SN95 4.6L Mustang Tech
Ignition switch problem. Please help!
  • Thread starter Thread starter eagle_011
  • Start date Start date Jul 18, 2005
E
eagle_011
27
Roanoke Rapids, NC
Jul 18, 2005
  • Jul 18, 2005
I have a 96 GT that had been doing perfectly fine. I moved it in the yard, then cranked it again and moved it back to it's normal parking place. While i was in the car i turned the switch off and turned it back to ACC. mode. I listened to some of a CD and then turned the switch off, but everything stayed on like it was still in ACC mode. So i stuck the key in and moved the switch back again and then forward and when i turned forward the dash lights came on like i was going to start the car. So, i flipped it back to the lock position but everything still stayed one. Now, the switch moves to every position, but the ignition itself is staying on. I can't start the car, but i can't turn the ignition back off either. Any ideas as to what to do to fix this problem? I need my car.
Thanks,
Jason
R
Roger_4.6_96
1,209
Reno,NV
Jul 19, 2005
  • Jul 19, 2005
Its easy but you gotta take apart lower part of your steering wheel and remove the ignition 3-4 screws and release button for ignition(gotta be turned to on position). Im not sure if you gotta remove the part by you knees connected the the dash. Once you take all of that off its really easy like 2 screws.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
