Ignition switch woes
  • Thread starter Thread starter Edster
  • Start date Start date Jan 11, 2012
Edster
500
League City, Texas
Jan 11, 2012
  • Jan 11, 2012
I can't get my switch to turn to the ACC position. The key fits and allows me to turn to ignition and start modes but won't let me move it ti the Accessory position. I7m thinking there may be something wrong w/ the lock cylinder. I've spayed WD-40 and jiggled the key every which way. Any suggestions?
guevara42
68
Jacksonville, Fl
Jan 12, 2012
  • Jan 12, 2012
I had the same problem a while back. I did the whole jiggle the key and it would work from time to time but it kept getting worse. Eventually it didn't work at all. I just ended up replacing it with a new unit.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Jan 14, 2012
  • Jan 14, 2012
Same thing here.
rbohm
6,698
550
204
tucson,az
Jan 14, 2012
  • Jan 14, 2012
yep, it sounds like you need to replace the tumbler cylinder.
Edster
500
League City, Texas
Jan 15, 2012
  • Jan 15, 2012
I also have switch problems too. I have the switch, but how do I get the old cylinder out if I cant get the tumble cylinder out? Can I drill it out?
Edster
500
League City, Texas
Jan 17, 2012
  • Jan 17, 2012
I went to a locksmith and had him cut a copy of the key but not as deep as the original. It worked! I was able to get the the cyl. out and replace the switch. Granted the key was made from a copy of the worn original. I might just get a new lock cylinder.
guevara42
68
Jacksonville, Fl
Jan 21, 2012
  • Jan 21, 2012
You don't want to drill it out. Stick a paper clip in the little hole that's in face of the switch, turn the key counterclockwise and pull it out. Do this while the paper clip is in the hole. I know you said you were having trouble turning the key to the ACC position but that's the proper way to remove the switch.
A
ai5u
  • Feb 1, 2012
Mine was the opposite effect. I could easly turn it to ACC but it was sticking on IGN and START. Ended up buying a new tumbler and key from NPD. Works just fine now. Luckly my switch is still good. Tumbler is much easier than pulling the whole mess to get to the switch
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
J
2000 Ford Mustang GT No Crank No Start please help
  • Jowen216
  • Jun 5, 2024
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Jul 5, 2024
Jowen216
J
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
J
Help! 78 II has no power to any electrical except headlights and taillights and hazards.
  • JackH
  • Jan 8, 2024
  • 3 4 5
13K
1974 - 1978 Mustang II Talk & Tech Mar 28, 2024
