93 LX. Bone stock 4 cylinder. I bought it and had to put an ignition switch in it as the original was falling apart, which I read is kind of common. New switch is supposed to have a wire on it that holds the switch together, the wire was off, so I just installed it and it works. However, it's like it is way too sensitive. With the key turned to "run" position, if you barely touch the lock/key, the switch turns off. Where'd I mess up?
