Ignition terminal
wild70stang
317
Ok, I finally found the terminal that you are supposed to splice into if you were to add a pertronix flame thrower coil, the picture is below. But my question is once you add the new wire, can you bypass the wire connector at the bottom of the steering shaft completely? or does the new wire have to run through it?
