ignition
slone420
I Have A 68' And I Have Had A Enormous Amount Of Trouble With Stalling. The Stalling Is From Losing Spark To The Ignition. It Has All Mallory Ignition With Auto Lite. I Am Not Getting Spark To My Distributor, It Is Not The Coil, Changed... I Also Changed The Resistance Wire From The Key To The Coil Because Of Lower Than Expected Voltage At The Coil. I Now Believe That It Is A Bad Connection Or Dirty Connector Under The Dash. I Don't Feel Like Taking The Dash All Apart Again,... Does Anyone Know If I Can Bypass The Key Ignition And Install A Switch For The Voltage To The Coil????? Thanks For Any Help.
Do you mean UniLite? If so, I've gone through about 2 or 3 of the damn LED part inside of it with mine. It's been so long since I've had my car on the road, but when I did, I had nothing but problems with it.
Unless anyone else has any ideas, that's where I'd start.
-John
