There is a ton of stuff to convert over. Yes the cowl is an issue, you don't wanna know the hrs spent to convert it. You will also need a 79-82 hood it is the ONLY one that will work other than aftermarket and they are like 475 ea for those years. You need the upper cover, lower valance header panel, and fender extensions. The hood can be cheap enough (hell I have a spare for the right price) the fnder extensions can go as high as 100 a set the lower is a couple hundred in rough shape. The upper can go for 400 plus header panels are hard to find unless with a front. Almost every lower is warped. The fog light bar is hard to get and can be 100+ fog lights are like 100+ etc etc etc I don't want to convince you not to do it but it can be damn pricey and might take over a yr to get all the parts. Best bet would to be to find a donor (82) do not hack a 79 pace or a 80-81 COBRA thats just wrong. Don't hack a 82 either. I got mine of a 87 that some asshat did a swap on. I would not bother for all the effort. I would put a lower air dam on yours and paint it. Its just not worth the $ Save it for a motor, trans, suspension, etc. Just my opinion but I have been there. Here is a pic of an 84 w/ a lower
See what I'm saying
