Im having roll bar problems!!!
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
I ordered a 6 point roll bar from maximum motorsports. It came in, and when i test fitted it, the back 2 bars seemed to be about 1/2" shy of where the pads are supposed to make contact on the wheelwells in the back. (this was with the back 2 bars bolted in place where they were supposed to go)
I advised the welder of this, and when he welded it together, he must have forgot. (bastard) When i slide the roll bar into place, the front door bar pads, and main halo pads line up square, but the 2 back bars are about 1/2" away from where they need welded to the wheelwells. I havent taken a picture of this yet, so i used my mad sloppy MSpaint skills to give you an idea.
The top picture shows the bar, and how its sitting in there now. notice the gap between the back pads and the wheelwells.
The second picture shows what i think i need to do to fix it. I am thinking of cutting into the rear seat bulkhead to slide the pad through an extra 1/2" to close the gap on the back pads. Im wondering if structurally this is a bad idea. Im going to slide it in till the main bars of the halo are touching the rear seat bulkhead, then weld the bars to the bulkhead, the pad to the floor, then go underneath the car and weld where its coming through the bulkhead.
does anyone know if this is illegal for the track, or does anyone have any other suggestions??? The actual picture of my floor pan shows where i would be cutting the hole for the pads to slide through.
rear seat bulkhead where i would be cutting out the little green box
If i do, there is a gap between where the back 2 bars meet the halo. and i think for it to be legal, the back bars have to be welded AT the halo.
Call maximum motorsports.
I did and they pissed me off.. he told me that all of them are made in a "batch" to the same standards, and they have never had that problem before.
If you do a search, a dude named "the huey pilot" or "huey pilot" had a thread about the exact same issue. he had to take a block and a jack, and jack up his floorboards in the front to make his work. I dont want to have to raise the floorboards and make the halo not straight up and down if i can avoid it.
Beat it with a Sledge hammer
a BFH will fix everything
lmao.. i was sitting at home last night thinking the same thing. I then realized that if i cut the hole like i was thinking, it wouldnt make it any different, it would just move the bar back a half inch, it wouldnt angle it to the wheelwells any better. I might just take it somewhere and have someone else figure it out. im tired of racking my brain about it.
Being a welder fitter, myself, I can't imagine why this guy didn't tack everything in place first. Hm.
Could it be a case of the actual roll bar itself, being out of square? Possibly tilted at the top a bit too much towards the windshield? Just a suggestion.
That's the exact same cage I want to get next year. It was actually on this years mod list. But the list got bigger as I progressed and it grew around the cage idea....Next year. :)
~Jeff
~Jeff
dude this thing has been a pain in the ass. Honestly, it looks like the back 2 bars are just plain too short. I played with it for 20 minutes last night, and the only conclusion i came to was that the back two bars are too short.
Whenever you go to do yours if you dont just cover the wire bundle (the one that runs along the bottom of the drives side from the taillights to right under the dash) it is a complete pain in the ass. i should have just got some welding blanket to cover the wires, but i wanted it to be as easy as possible to weld and wanted everything out of the way, but some of those connectors, i know havent been taken apart, and there i was with 2 pairs of pliers pulling those things apart. But it gives me the chance to put them all in some new convoluted tubing and make it look good.. even if its going to be under the carpet.
This is just steel. Cut them off at a convenient location and weld in some extensions. Pain in the rear, may cost a buck or two, but it will work. Or simply fab up some mounts that go between the rear floor and the bars.
When I was in the shipyard, we used to say we could fix anything as long as they still were making acetylene and welding rod. And, yes, it's true.
I wonder why maximum motorsports welds the rear strut plates to the wheel wells. I have heard that this is not the optimal placement for the struts. My roll bar strut plates are welded to the floor just inside the wheel wells. Apparently the wheel wells are known for ripping out and destroying the shock mounts causing crazy damage if you get in an accident. My brother built my roll bar when he was at school at Wyotech and that's what they taught them...who knows.
Anyways, I dont know if i would hack into that roll bar to extend those rear struts....i would just send it back to MM and get them to send you another one. Is it completely welded in besides the rear struts?
Ill take some pictures for you tonight. They trimmed the main bar pads and some other things to make it work and fit right. I was under the impresion when i ordered it that the rear bars went on the sides of the spare tire well like half in and half out of the spare tire well (if you know what i mean)
When i called them to ask them what was up, they said that locating the back bars right over the rear axle was (to them) better in case of a rear collision so instead of the car buckling in towards the driver, it would buckle up in the back...
hell if i know, all i know is if there is a next car for me that i do this to, im dropping the car off at wolfe racecraft like someone suggested to me in the first place.
this is a very good example as to why these cage kits are not worth the time or money. I think that the MM stuff is still made by Autopower. At least you got it to a race shop and they were able to fix the problem.
cutting the body is not a good idea and will cause it to no be legal and be unsafe. I want to see what they did to fix the problem. I know what i would have done.
cut the plate on the main hoop and slide the tube tight with the body on the lower mount. then plate the tube to the body where it meets up with it and re-plate the one i cut to increase the weight distribution of the main hoop.
the style of the rear is also not optimal, the wheel wells will just shear in the event of a rollover and I’m not to thrilled on their design of the plate work on the main hoop either.
Jason
Jason
I would definately do this different in hindsight :nonono: They did exactly what you said, they trimmed the plates on the main hoop, and scooted the whole thing back about an inch. that got the plates on the wheelwells almost lined up, and also brought the main bar flush with the b pillar (it was sticking out too far to where you could see too much of it looking through the window.) they then pulled the main bar back flush with the rear seat thing (the hump where the front of the rear seat clips into) then welded the plate and bar itself to the floor and to that hump thing. that got the pads to line up right on the wheelwells.
I love the SFC's and other stuff MM puts out, but thier rollbars FTMFL :notnice:
