jesserose17 said:You can pull up the dist up, holding the rotor in same position and as soon as you feel the rotor is disengaged, move the dist body counterclockwise a little bit while holding the rotor in the same position. Then set it down, you will feel the rotor mesh with the cam gear. The rotor will move a little bit as you move it up and down.
I think you move the rotor, moving the body will not change the settings of the gear.I'm in Hammond--I teach at SLU. How's things over there?D.Hearne said:Where are you located in Louisiana, Paul? I'm in Opelousas and could take a look at it if you're close.
pabear89 said:I think you move the rotor, moving the body will not change the settings of the gear.
Lift the dist till you feel the gear free up from the cam and turn the rotor one tooth back.
You may have to bump the starter to realign the oil pump shaft.
PB
jesserose17 said:The object is to move the vacuum body away from the thermostat, not changing the timing, so there's more room to advance if timing change is necessary.
I find it easier to slowly rasie the Dist and while holding the rotor to feel when it just clears the cam gear and count the cam teeth that I move it.Anytime, but the strawberries aren't necessary , the wife likes em, but I never got hooked on them.MustangPaul said:I'm in Hammond--I teach at SLU. How's things over there?
If things don't get better, I may take you up on your offer. Don't worry--I'd bring some ponchatoula strawberries if I come that way!
-Paul
pabear89 said:Well you seem to have narrowed it down.
Use a vac pump to pressure and see if it leaks back.
PB
WORTH said:I thought you already removed the vacuum to the advance and it still surged, if that is the case the the diaphram is not the problem.
How tight is the distributor shaft, a warn bushing in the Dist. will cause the dwell to change while driving.
