Impact on harmonic balancer accidentally!
Creomod
5 Year Member
Sep 14, 2018
554
47
48
San Antonio,Texas
Ok I wanted to rotate engine by hand but didn’t want to remove the dizzy soooo I thought let me use the impact,I did and I heard it tourqing and I stopped! Well now I’m turning engine over by hand with wrench and it feels different. Like harder to turn over. Spark plugs out no belt. I left the house and this just occurred to me. Think ,is it possible I tightened the harmonic bolt and that’s what’s causing the resistance. It’s like 30lbs to turn over but I swear it just feels like it has the spark plugs on it. I just built it and I remember I just did valvetrain few months back.
No. An impact is how you tighten a harmonic balancer. A little extra torque wouldn't cause it to turn over harder. Not sure why you would attempt to turn an engine over with an impact.
Kurt
Unless your impact looks like this:
Then you're probably ok. O_o
It's okay. Many years ago I left the wratchet I used to turn the engine over on the balancer socket, when I started the engine. It hit the radiator hose, and backed the balancer socket all the way out. 2 gallons of antifreeze wasted to pull the radiator back off so I could get the impact back in there to tighten the balancer again.
Kurt
Kurt
I left a wrench on a cam bolt on a Mitsu Galant GSR... :doh:
Cranked it over and completely wiped out a new head... on a new motor... :suicide:
I win! :jester:
  • Haha
Reactions: revhead347
Kurt
This sounds like a very easy way to remove the bolt.
