Impact wrench options
  • Thread starter Thread starter BlackVert
  • Start date Start date Dec 31, 2011
First Prev 2 of 2
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jan 5, 2012
#21
  • Jan 5, 2012
  • #21
Oooh, you're lucky you got the warranty.
4Jenna
4,326
AZ
Jan 5, 2012
#22
  • Jan 5, 2012
  • #22
I love my coordless impact use it alot. Buzzing lugnuts on/off, motor work, exh work, etc. I use it much more than my big bad boy NAPA pnuematic one. The big one is a must have to for the serious stuff.
I carry it with me when ever I go to buds houses to work on cars and always to the track. I use a craftsman I got when I went to buy a drill, drill/impact (19v) for 99$
Husky44
865
104
74
Tacoma, WA
Jan 5, 2012
#23
  • Jan 5, 2012
  • #23
I've never used a cordless, so I can't compare it to the impacts. I used to use a portable air compressor (seems like it was 30 gallon). I started with a 25 gallon Harbor Freight; it was a waste of money; when I took the second one back they refunded my money and I bought a Porter Cable. It got the job done for turning wrenches, but if I was doing anything that took a continuous air supply, it was wheezing pretty quickly.
IMHO, the single best thing you can do to get good use from your air tools is have a GOOD compressor.
I got an 80 gallon with like 11+ CFM. It'll rock an air gun!
BlackVert
5,589
9
98
Bethesda, MD
Jan 5, 2012
#24
  • Jan 5, 2012
  • #24
what ... do you know something bad about the husky compressors that i should find out?
Husky, those 80 gallon ones are EXPENSIVE!
R
redsn95gt
143
#25
  • Jan 6, 2012
  • #25
If you want to spend a little more, the Husky (Home Depot Brand) is actually pretty good and has a good warranty. They are competing head to head with Sears/Craftsman. This deal is probably the best bang for the buck, $449 for a 60 gallon with enough CFM to run just about any tool you want for a good period of time. Might not be able to paint a car lol but its gonna work good for small jobs.
http://www.homedepot.com/Tools-Hard...splay?langId=-1&storeId=10051&catalogId=10053
If you don't want to spend that much, then you can go with this portable at $249 which is small as I would go. I actually own one of these and its good. Its only 26 gallons but for auto tool purposes it works great and its easy to haul around still. I've actually done some small paint jobs with this like my engine bay.
When it comes to harbor freight tools, yes the impact guns are great, but most of their air tools suck a lot of air i've discovered. I don't use some tools as much thats why i only got cheapys but if you used for example a cutoff wheel a lot, the harbor freight ones drain the tank quick where as a pro tool holds air a lot better.
EDIT - One more option- i've randomly seen industrial air compressors on craigslist from businesses getting rid of them or going out of business. You'll need a truck to haul it but i've seen some pretty incredible deals they just wanna move this stuff most of the time.
BlackVert
5,589
9
98
Bethesda, MD
Jan 6, 2012
#26
  • Jan 6, 2012
  • #26
redsn95gt, funny you should mention Husky, because that is what i ended up with. i got a 33 gallon Husky at home depot for $249 because it was a floor model and didn't have any of the accessories. but it has the same warranty (1 year) and i got 2 more years for extra peace of mind.
Venom351R
4,548
41
98
MAINE
Jan 7, 2012
#27
  • Jan 7, 2012
  • #27
I have a craftsman portable torque wrench but I only use it for breaking loose lug nuts when I change tires at the track. Other then that I dont use it for anything. For heavy impacting I have the compressor and craftsman air gun at home
Bosko5.0
1,067
longwood, FL
Jan 7, 2012
#28
  • Jan 7, 2012
  • #28
I run a Matco 1/2" impact and a 3/8" butterfly impact on a 13gal or a 5gal with no problems.
BlackVert
5,589
9
98
Bethesda, MD
Jan 7, 2012
#29
  • Jan 7, 2012
  • #29
There's a guy on my local craigslist selling the Dewalt 18 volt cordless 300 ft/lbs impact wrenches for $105. i'm not sure if it comes with a battery and charger or not. if so, i might get it because that is a great deal.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jan 8, 2012
#30
  • Jan 8, 2012
  • #30
I've found that if you want to find good air tools, go drag up some old stuff. There is almost always a guy at the flea market selling rebuilt air tools. That's where I got my IR 231, which is the standard for shop impact guns.
Kurt
BlackVert
5,589
9
98
Bethesda, MD
Jan 10, 2012
#31
  • Jan 10, 2012
  • #31
any thoughts on Campbell Hausfeld stuff in general? i know the power is not very high, but the price is right
Campbell Hausfeld 1/2 in. Impact Wrench - 250 ft/lbs - $29.95
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jan 10, 2012
#32
  • Jan 10, 2012
  • #32
I bought that exact Cambell Hausfield impact gun just for doing light work when I was at Firestone. I knocked about 3 lug nuts off with it at the shop, and all the hammers cracked. The air tool guy wouldn't give me $1 for it.
Kurt
BlackVert
5,589
9
98
Bethesda, MD
Jan 10, 2012
#33
  • Jan 10, 2012
  • #33
that is exactly the case where you take it back and get your money back, or a replacement.
BANGERSTANGER76
286
9
DETROIT PLUGZONE 76
Jan 12, 2012
#34
  • Jan 12, 2012
  • #34
Air tools are most def the way to go.
I got a 2 hp, 12 gallon compressor with that 700 ft lb Earthquake wrench. and I have no problems tearing down anything. It knocks off hub bolts, suspension bolts everything I put it up against so far. never one problem. FYI your compressor must be atleast 1.5 hp to get good power for the wrench.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jan 12, 2012
#35
  • Jan 12, 2012
  • #35
You don't need much of anything to run an impact wrench. It's the tools that wrong for a long period of time, like an air hammer, or an air drill you need a big motor for.
Kurt
First Prev 2 of 2
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Torque Wrench calibration
  • crucifyd
  • Oct 10, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 10, 2023
Bullitt347
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
