in need of some pics and measurements
hey guys. havent been on here for a while. doing a lot of research on other boards for my next big project and i need some help.
my car is in storage already :( so i wont have access to it till spring.
i need some good pics of the floor pan under the passenger seat. i need to know how much room is there. if you can get me some measurement that would be even better too.
i want to put an amp like case there that will fit nice and flat to the floor. it measures 8.3" x 10" x 2.2" / 210mm x 254mm x 56 mm.
if anybody can help me out that would be great
thanks
Here's a few pics for what there worth ....If you have subs then you lose more space...Fuel lines run down the pass side and you can see from the back the exhaust is gonna throw some heat if to close??
Have a rear seat delete?? tons of space under there...
i actually need pics from the inside of the car but that helps me out too
i still have rear seats even tho i barely have any rear passengers so i cant do that.
it looks pretty flat where the rear seat is tho.
on a side note, i noticed you still have stock control arms. any plans for an upgrade?
Hey Dan I have some pics of the floor pan under the carpet from when I replaced my interior last year but I do not have any measurements for ya.
I took the mesaurments, but cant find where I wrote them down. Ill get them for you tommorrow. But Im pretty sure it was like 14.5x11.5 from the bolts.
There is a hump that will take up some space but if you really want you could have it removed I guess. :shrug:
Dont mind the black stuff, I wwas seeing which dye worked better. :D
Theres also a hump where the front bolts are. It goes up to about where the wire comes out of the floor. I can see that being the biggest pain in the ass.
But as far as hight goes, I think it will fit. Ill get the measuremnts for you in a few hours.
