Engine In The Wilderness
Great advice from all. If its combustion pressure getting through, then it will bubble in the coolant immediately from the leak b4 it even warms up. It may b very little bubbles @ idle but will still b there. At least u can cross that off the list if u dont see that. Have someone help u do a compression check to see if there is a problem with a specific cylinder just to confirm. I agree, its sounds to me like lean carb and timing is off. Remember a stock cam is around 6 degrees btdc @ idle and a performance cam will want 10-12 degrees btdc @ idle average. Many have installed an aftermarket cam @ the stock timing specs. Big no-no. Follow cam company recommendations. Also replace ur radiator cap if u haven't already. The original is probably worn out and wont hold the required pressure to work correctly.
