This crate engine has already been fired/dynoed, so all internal components are in working order.
- I've checked my TPS 0.98=closed 4.57=WOT
- Initial timing is set to 10 BTDC
- Using tweecer, I adjusted cranking PW down by 19/30# injectors (0.63333)
- Fuel pressure appears to be around 39.
Hard to really tell when I'm starting.
After I attempt to start the gauge is reading 39.
- With throttle body (TB) closed - some small pops from tail pipe.
- With throttle body WOT - the pop become more aggressive/loud - at one point it did seem that the engine
was going to start -
Ideas ? Suggestions ?
