Injector brand
95wanttobe
25
I've done a number of searches but can't really find a definite answer. Is there any real difference in brand?? name of injectors. I know Bosch is good and also $$$. Accel or Ford SVO, any real differences in quality. What do some of you use. Thanks --- Have a good Memorial Day.
Pretty sure all the inj's used by Ford are made by Bosch
I see an advantage in sticking to that brand cause most peeps use them
and if you need help or info about them it will be more likely you can do
what you wish as opposed to using some brand that not many peeps
have used
Grady
Ford primarily used Bosch and Denso on our cars. Both are good, reliable, and prodcution quaility (better than aftermarket). The big thing to consider is injector opening time and flow rate. If you go with aftermarket and these specs aren't disclosed, it can be very hard to get a cusome tune that works well. And don't do the MAF tuned for the injectors thing, that's just a bad work around for a proper recalibration of the ECU.
Depending on what flow rate you want, check out Buy Ford Racing Parts! They have some awesome deals on 24, 30, and 42 pounders right now. Click on the specials tab and check it out. I think these are Bosch injectors but I'm not sure. You could probably call FR and ask.
