  • 1994 - 1995 Specific Tech
Injector size
  • Thread starter Thread starter topless95
  • Start date Start date Dec 23, 2008
T
topless95
27
North Florida
Dec 23, 2008
  • Dec 23, 2008
I am installing a set of x303 heads, a E-cam, performer intake this weekend and was wondering will I need to go to 24lb injectors to get the full benefit of the H/C/I upgrade? Also would I need to upgrade to a 70mm throttle body?
As always thanks in advance
Jim
Adam95GT
2,564
Burlington, NJ
Dec 23, 2008
  • Dec 23, 2008
id do injectors and pump for sure... with any HCI swap its my vote that it needs to be done to run its best.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 23, 2008
  • Dec 23, 2008
Is your heart set on that E cam. Those motorsport cams are only good for making noise, they really don't let the heads breath the way they should. You can get away with running stock injectors. If you can't get injectors by the weekend, don't let that hold you back. They are easy to change later on. It would probably run better with 24s though.
Kurt
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 23, 2008
  • Dec 23, 2008
IMHO ... 24's are too small for even a very mild h/c/i combo
I base that on being a self tuner
so
My perspective is from ...........
Running OEM fuel pressure
Now ... if you elevate the pressure
and
If ... you go up on the intank pump size
The 24's can get you by
I'd not sleep good at night with h/c/i and runnin the tiny OEM 19's
Grady
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 23, 2008
  • Dec 23, 2008
30s are too big for that engine. 24s are more than enough. 70mm or 65mm throttle body will be fine.
Kurt
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
