Injectors too small for 331?
  • Thread starter Thread starter 281pony
  • Start date Start date Dec 21, 2004
281pony
2,681
Oly, WA
Dec 21, 2004
  • Dec 21, 2004
i have a chp 331 pro street stroker, ported performer rpm intake, ported rpm performer heads, 1 5/8" equal length headers, o/r h-pipe, 1.6 rockers, 274hr camshaft, ect. 190 in-tank fuel pump.
i just bought 24# injectors and matching pro-m. ive seen people running 24's and 30's.
with a combo like this should i be safe with the 24's at 40 psi? or should i run them a little higher? its a street car, and will probably never see more then 5500 rpm if that.
just want to be safe with this engine after my last experience. thanks for the input. i know there is a guy running a really similar combo to me but i cant find his name for anything.
87fcoupe
57
  • Dec 21, 2004
24 will be fine but 30 be better.With the money you spend on that setup,first I would do is take it and have it dyno tuned after break in on the engine.Good Luck.
281pony
2,681
Oly, WA
Dec 21, 2004
  • Dec 21, 2004
id really like to.
im going to do an easy driving break-in. i know its a big arguement on how you can do it. im going 100 miles, oil change, 500 miles, oil change, 1000 miles, oil change. then again at 3k. easy shifts, no higher then 2500 rpm.
the thing with the dyno-tune is there isint really any places around here that im comfortable going to. they are a few hours north or south of me. there is one shop about an hour north, but everytime i hear feedback its misleading. well see, i definately want everything to be done right though.
87fcoupe
57
  • Dec 21, 2004
Good dyno tuner you could easily pick up 20+ horses on that motor(N/A).So if you can I would recommend it.
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
Dec 21, 2004
  • Dec 21, 2004
I ran 24lbs on my 331ci with TW heads, Track Heat intake, 75mm Pro-M, 65mm TB & EGR, 1 5/8" shorties, 2 1/2" rest of way back. Untuned a/f was good final tune saw 340rwhp/360rwtq w/12.8:1 a/f across board.
24 will work but as was mentioned 30 are better.
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
J
Engine LOSS OF POWER AT 4,000 RPM.
  • Jarhead67
  • Nov 17, 2024
3K
Fox 5.0 Mustang Tech Jan 25, 2025
Jarhead67
J
