I tried to install my Canton Oil pan. I used a FelPro gasket, coated each side with Permatex gasket sealant, installed the rubber end pieces, dropped the pan on and torqued the bolts to about 8 in.lbs for the 1/4 UNC and 10 in.lbs for the 5/16 UNC. Result, the gasket extruded and split across about three of four of the 1/4 UNC bolts.
Where am I going wrong guys? Tips and techniques for presed steel oil pan installation please.
