HISSIN50 said:V8, glad to see we are on the same page (not disengaging all the way equaling being too loose, as you put it).
5sp, yep, if the wheels dont turn with the clutch pedal in and it in first, it is disengaging all the way.
do be very careful with the car while it is on jack stands. i mean real careful (it is actually something i personally dont recommend to strangers, as it can go wrong).
now NOTE: since you say the vibes go away when depressing the pedal an inch or so (which i did not know before), i agree with V8 about the TOB. i would just dial in a bit of preload (as you should anyhow) so you know you are disengaging the clutch as much as possible and see what gives. it may simply be a TOB/retainer issue.
good luck bud.
Thanks Hissin and V8- Alright well the wheels don't spin until about an inch and a half off the floor (rear in the air)...that is when it just starts to spin...
So you think that if I (turn the firewall adjuster to the left) makes it grab higher up that it might press the TOB against the pressure plate more and possibly get rid of the vibe...
Will this "sometimes" occuring clutch pedal vibration hurt anything if I take down the track a couple times...
It didn't vibrate this morning but when I got out of class I went to Wal-mart to pick up some new Autolite 3924's and it was vibrating...
) was considerably harder than the King Cobra...the KC feels mushy compared to the previous...so I am happy
