Im starting to hate this now...
I just finished installing 24LB Injectors w/ Granatelli 77MM MAF, BBK Fuel Pressure Regulator, Performer Intake and a PAXTON SN-89 Series Charger w/ FMU -
1st when i started it up.. I had a hue fuel leak from injectors not proprerly installed... Fixed it and re used same gasket of the intake ..
2nd i started up the car.. Hear a loud whining sound, this is not from the charger and is coming from the upper intake.. Everytime i press down on the intake the sound dissapears... Sounds a loud cat meowing....
3rd - My idling is wayyy high....when i start up the car after 10-20 mins of being park.. The rpm stays @ 1300 then drops to 1000 then to 700....
Now my main stress factor.........
I dont feel any boost or power from the charger.. The charger worked fine in my buddies car and boosted @ 8PSI...
I havent set my timing to 8* and havent changed the stock spark plugs.... I also havnt tuned the regulator....
What is causing all this mess? Vaccuum leak?
Lets see who can figure this ***** out!!
