Anyone else have a TR3550 or 500, or 600 installed in a fox body, mine is a 93 and I just swapped over from a T5. I also purchased a B&M ripper shifter for it. Everything is working mechanically but my shifter seems way over to the right side of the console. When I installed the shifter it was hard to get to two of the right side mounting bolts, but the left side was perfectly clear. It just seems like it is not centered in the tunnel. However the crossmember fits fine? The big hump is on the passenger side. Since the B&M shifter is a one piece design and does not have the offset that most bolt on handle shifters have, is that why it seems so far to the right? I may try the factory shifter back on it. The Trans is a NOS TR3550 that had 0 miles on it.
) will amplify this.
