Installing a Cam..help?!?!?!
  • Thread starter Thread starter 93stang351w
  • Start date Start date May 13, 2004
9
93stang351w
50
minneapolis,minnesnowda
May 13, 2004
  • May 13, 2004
just bought a cam from comp cams with .510" and .512" lift. putting it in a 351w, the engine is out of the car on a stand. What are step by step directions to install a cam??..i have little experience on mechanics so every bit of info helps...i thought i just had to take off the water pump, timing gears and chains, am i right?..or do i have to take of the crank pullie ,dampner, and the front cover?? any special tools ill need to take the crank pullie off??? someone please help its greatly appreciated ..thanks!!
-86GTStang
165
Norway, Scandinavia
May 13, 2004
  • May 13, 2004
Use the internet, search for info at Comp Cams, Trick Flow or buy yourself a Repair manual / or a book including this.
You need a lot of information, and its to much to write down here.... Good Luck
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
May 13, 2004
  • May 13, 2004
just take off the timing chain cover leave pump intact if possible, timing gears and chains, you will have to take of the crank pullie ,dampner, and the front cover any special tools? Yea a balancer puller.
9
93stang351w
50
May 13, 2004
  • May 13, 2004
thanks for the responses
W
wisconsinboy
78
eau claire wisconsin
May 13, 2004
  • May 13, 2004
get some engine grease too. dont know if you knew this but you gotta smear it all over the journals and lobes of the cam before you slide it in. also it helps if you got at least one of the bolts that holds on the gear on the end of the cam so you can slide it in straighter so your not hitting the cam lobes on the bearings or anything.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 13, 2004
  • May 13, 2004
Are you degreeing the cam upon install? You do have the manifold off and the lifters out, right?
9
93stang351w
50
May 13, 2004
  • May 13, 2004
no i wont be degreeing the cam....but ill take the lifters out once i can get ahold of a balancer puller....so ill need the take the rockers off then pushrods then the lifters?
88stangmangt
2,332
Stafford,VA
May 13, 2004
  • May 13, 2004
yes.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 13, 2004
  • May 13, 2004
93Stang - the way you're asking questions leads me to think you might be in a bit over your head here. I'd suggest you get a buddy that's done this before to help you through the first one.
M
Matts89LX5.0
1,314
Long Island, NY
May 13, 2004
#10
  • May 13, 2004
  • #10
I had a friend help me install my first cam in a motor. Much easier to watch someone do it first.
Matt
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Questions Replacing Cam Synchronizer
  • Blackout67
  • Jul 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 23, 2025
01cstang
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
J
Fox Cam swap gone wrong??
  • Jimmer009
  • Apr 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
Jimmer009
J
