Installing a cam "Straight up"
  • Thread starter Thread starter mob
  • Start date Start date Jul 27, 2009
First Prev 2 of 2
Bryan83taco
554
40
39
SF Bay
Jan 2, 2012
#21
  • Jan 2, 2012
  • #21
Triple post
Bryan83taco
554
40
39
SF Bay
Jan 2, 2012
#22
  • Jan 2, 2012
  • #22
Triple post sorry
CarMichael Angelo
8,909
234
Birmingham, al
Jan 3, 2012
#23
  • Jan 3, 2012
  • #23
Bryan83taco said:
I picked up trickflow's degree kit so I can degree and retard my tf stage 2. Retarding the cam should make some more power lower on the rpm band.
( You really wanted to be sure we saw your reply I guess)
Hopefully you already have an Idea of how much power, and where that power is occuring currently.
This has always been a point of contention for me. Degreeing the cam as a manner of double checking the mfg's figures is one thing, deciding to retard or advance a cam before it's even ran is a WTF? Moving a cams' timing around to build more power is for somebody trying to eek out the last bit (of torque or power) as long as they have a dyno and a bunch of time to check what they did, AND as long as they had a baseline for the power the cam made installed "straight up".
And you're right Bryan, retarding the cam should make more power lower in the RPM band, but how will you know? Even if you do know how much power your engine makes now, I assume that your going to use something more substantial than the "seat of the pants" dynojet to check whether or not retarding the cam was worth the effort.
blykins
122
Louisville, KY
Jan 3, 2012
#24
  • Jan 3, 2012
  • #24
If it has advance or retard built into it, it's not "straight up."
What guys refer to as putting the timing chain on dot-to-dot doesn't not mean that the cam is installed straight up. It just means that you put the timing chain on dot-to-dot without using the advance or retard keyway on the crank gear.
Bryan83taco
554
40
39
SF Bay
Jan 3, 2012
#25
  • Jan 3, 2012
  • #25
Sorry about the triple post. And thanks for the good info mad mike. It makes sense, I should get the baseline first and then adjust if I need or want to.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jan 3, 2012
#26
  • Jan 3, 2012
  • #26
Uh, yes it is, because you still install the cam dot to dot. The advance/retard is literally part of the cam grind itself, not the orientation of the cam installation. The lobes themselves are ground advanced or retarded. I'd have to check the specs but i'm pretty sure my cam is 2 degrees advanced and i installed it dot to dot.
blykins
122
Louisville, KY
Jan 3, 2012
#27
  • Jan 3, 2012
  • #27
Then it's 2 degrees advanced, not straight up.
Setting the timing gears dot to dot does not mean straight up. I promise. The term "straight up" only refers to the LSA being equal to the ICL.
Some examples:
110 LSA, 106 ICL = 4 degrees advanced
110 LSA, 108 ICL = 2 degrees advanced
110 LSA 112 ICL = 2 degrees retarded
110 LSA 110 ICL = straight up
If you don't believe me, call up your favorite cam grinder and ask them...
Brent Lykins, B2 Motorsports
www.b2motorsportsllc.com
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 3, 2012
#28
  • Jan 3, 2012
  • #28
Agreed.
First Prev 2 of 2
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
J
Fox Cam swap gone wrong??
  • Jimmer009
  • Apr 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2025
Jimmer009
J
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
